Question about Casablanca Fan (1928D) Table
Casablanca Table Fan, DOA
If your Casablanca Fan (1928D) Table Fan has stopped working completely, or stopped in the middle of oscillating, it might be the internal AC wire that runs up the middle of the fan base, that is broken internally. First, make sure the fan is not plugged in. You have to take the whole fan apart from the front. Check for continuity on the white and black wires that run to the motor. You may have to pierce the black and white wires with a pin to check them, because they are wired directly into the motor. These two wires have a black jacket covering them that can be pulled off if you find an open wire. Either one of these wires can break internally because of the back and forth movement. Cut the wires close as necessary to the motor to make the splice. Solder and use heat shrink insulation and route the new wire back down through the base and splice them where the original wires were. I used a piece of electrical cord with white and black conductors that was cut off an appliance that was dead. It was the same size as the original so it fit well. Please note, this repair requires electrical and mechanical knowledge. You have to take the whole fan apart to do this repair.
4 Suggested Answers
1beertap
  • 32 Answers
SOURCE: Casablanca Fan W21 Ceiling Fan
Hook the fan's wires up as follows: black = black (hot) white = white (neutral) green = green or bare copper wire (ground) red = not used, so cap off (hot) The red wire is for a light kit. You may have a second switch on the wall to control this. Usually, the ceiling fan will have a red with a green tracer wire that goes with the red wire. If not just cap the red wire off and don't use it.
Posted on Jun 10, 2007
  • 21 Answers
SOURCE: 1998 ford Taurus 24v DOHC Overheating not thermostat
check to see if eans coming on if they dont then its fan relay if they are the rad is pluged or ther is an air pocket in the cooling system there should be a bleeder on it
Posted on Oct 06, 2009
  • 405 Answers
SOURCE: The Casablanca 88U33M Scandia Ceiling
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Posted on Jul 04, 2011
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    Tip
    on Apr 21, 2014 | Casablanca Fan (1928D) Table
    Casablanca zephair
    The on Zephair came with the old intellouch control,which is a special control for that fan. If that is what you have then call 1-800-715-0393 with model# & serial#
    Mar 24, 2013 | Casablanca Fan 1928C Zephair Satin Brass...
    My inteli-touch casablanca fan won't turn on at all (light or fan). Today there was an interruption of electrical power to the house and now the fan won't work. I know there is a way to "reset"...
    I have had 3 casablanca intellitouch fans stop working. All 3 had the same problem. The 1000uf/35vdc capacitor failed. Replaced with 1000uf/50VDC cap from Radio Shack. No problems since.
    Nov 09, 2010 | Casablanca Fan 3245T Ceiling
    Oscillating table fan makes banging noise when rotating
    mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
    Jul 24, 2010 | Holmes Products Holmes HASF1304S-UC 12",...
    Remote stopped working, fan and light do not
    click the reset and turn off the fuse box and then turn on
    Feb 15, 2010 | Casablanca Fan 3245T Ceiling
    Electric Table Fan: works only if held at certain angle
    You may have a defective shafting, or bushing or just plain stuck. This can also damage fan cap. But the way you describe it, your cap may be bloating already.
    The knob could be taken off, check if it is have screw(or in the middle of it), some maybe a screw type knob, or you have to pull it with just enough force.
    Jun 16, 2009 | Dryers
    Casablance Ceiling Fan Trouble
    itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
    Jul 16, 2008 | Casablanca Fan 3245T Ceiling
    Casablanca Fan (1928D) Table Logo
    Top Casablanca Fan Dryers Experts
    Jerry Greenberg
    Jerry Greenberg
    Paul Bade
    Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
