Question about Gigabyte GAH67MAUSB3B3 Motherboard Intel Core Socket 1155 Intel H67 mATX HDMI RAID SATA LAN (rev
GA-H67MA-USB3-B3 RANDOM SHUTDOWN AND REBOOT
Computer is about 1.5 years old. It has started random shutdown and reboot while in use. It has a tendancy to loop restarts taking 2 or more attempts before it will boot up and be useable.
  • 111 Answers
SOURCE: GA-EP43-UD3L restart loop
Flash It!
http://www.gigabyte.us/Support/Motherboard/BIOS_Model.aspx?ProductID=2995
Posted on Aug 20, 2009
SOURCE: ga-k8ns memory problems
It appears that the manual for the GA-K8N-SLI, Pro-SLI, and Ultra-SLI states you can use 1 GB, 2 GB, or 4 GB as a memory configuration. The 3 GB is not supported (possibly because one bank would be dual mode and one bank is single mode). The 1 GB configuration should have one stick in slot 1 or 3. The 2 GB configuration should have a stick in slots 1 & 2 or 3 & 4, but 1 & 2 is preferred.
Posted on Aug 21, 2009
  • 12 Answers
SOURCE: after psu burned out , can't boot computer with
You might Have a Short on your Mobo, switch around your Jumper Config, check for any metal material touching any traces :]
hope this helped!
(try reseting stuff aswell, when things vibrate they move IE: chip creep)
Posted on Sep 04, 2009
  • 14 Answers
SOURCE: GA-EP43-UD3L Reboots while loading Windows
its due to bios problem , upgrage bios from biostar web
Posted on Oct 26, 2009
omnittron
  • 11 Answers
SOURCE: Motherbaord won't boot
hello
My mother has the same motherboard. It's been a long time since we had bought in a bazaar, as an old piece of scrap that will be sufficient for my mother to surf the Internet and start with a computer.
But after some time, my mother began to paint in Corel and Photoshop, and she began as a teacher to produce a school magazine.
And that's the motherboard scrap really scrap.
First, I swapped memory.
And when I swapped the memory and turned on the pc again, so I had the same problem as you.
But the solution is not so complicated .. So how to get rid of beeping sound after you improved a hardwear?
Turn off the source, after unplug the network card (you do not remove it out, just pull the cord RJ14), as well as all USB connections (these mainly) .- As the old motherboard and simply not do it all at once.
After that you should turn on the computer without problems, run the plug again network cable and all USB and printer, and restart the system to save the settings.
I recommend download the latest BIOS and Install the http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=2307
After the motherboard does not have problem to boot after change hardwear.
After the motherboard can handle athlon 3000 and will be able to plenty else.
Now that everything is in the manual which can be downloaded from the same side as bios and other drivers.
I hope that I have at least a little help
omniTTron
Posted on Mar 13, 2010
Keeps trying to reboot when switched-on. Battery checked ok.
detach all what you can from the motherboard llet only video card , CPU and try to start is so and see the outcome.if is working put bak one at the time and wich is not starting that one is faulty.
Apr 29, 2016 | Gigabyte GA-H55M-USB3 Socket 1156/ Intel...
Unit starts/stops-starts/stops after replacing 3v battery?
When you say starts/stops (etc) are you saying it just keeps trying to reboot? Or are you getting a message such as boot disk not found press any key to restart? Replacing the 3V battery will cause the CMOS to reset to factory defaults. You may need to go into the CMOS and make setting changes to point to the proper disk drive for booting. You may even have to change the type of disc drive since there is now the old MBR as well as the newer GPT format. Also, there is the possibility that if you are upgrading you may need to use the legacy CMOS instead of the UEFI that many newer mainboards come defaulted to. Any error in the CMOS settings can cause a boot failure.
Apr 03, 2016 | Gigabyte GA-H55M-USB3 Socket 1156/ Intel...
Cant access bios or boot menu on ga-78lmt-usb3. tried changing keyboard but no luck.
Does the board work? Maybe you tried an unsuccessful BIOS upgrade?
How about explaining exactly what happens when you try hitting F2?
Mar 25, 2014 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
Computer randomly shutsdown without warning
option-1:
Many times battery indicator may show good, but in reality life of the battery might have gone down.
option-2:
Install an antivirus. It could be another program such as virus which is causing this reboot.
Feb 12, 2014 | Computers & Internet
Do gigabyte motherboards GA-7N400 pro2/GA-7N400/GA-7N400L support usb3 cards
Yes, but please make sure you buy the PCI interface version, some of available USB 3.0 card in the market are mostly PCI-express interface. Just tell the store you will install it on the old PCI slot (white one). You also ask them if they have issue with the card that they recommending to you.
Nov 04, 2011 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
I have upgraded to Windows 7 and also a new Gigabyte GA-H61M-D2-B3 Motherboard. 4GB DDR Ram I have plugged my Cambridge Soundworks SW320 in but I only get some sound, eg all music and back ground sound is...
Gigabyte GA-H61M-D2-B3 Motherboard supports 2/4/5.1/7.1-channel HD audio, whereas Cambridge Soundworks SW320 is 2.1 (only). Hence, the PC should be configured to provide 2.1 Channel output. The audio of your system may be configured to 2.1. So, please check the Realtec Audio sound manager/ configuration from the control panel or from tray (near clock) and set it to 2.1 (2 Channel Stereo Output).
Moreover, audio on your PC may be running on default HD Audio Drivers. So, you may also download/ install the latest drivers for Gigabyte GA-H61M-D2-B3 Motherboard.
(Refer to download section at the bottom of the page). After installing audio drivers, you would be able to configure the audio.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 13, 2011 | Creative Labs SoundWorks SW320 Computer...
I just completed a build of a new computer using an MSI H67MA-E45 rev B3 motherboard. Each time I reboot I hear 3 beep codes, 2 low-pitched and 1 high-pitched. Internet reading indicates a memory...
try them in the other slots if you can . and dose your board go that high with 8 gb.mem. check broad config for mem some will not take that.also see spec. of mem if not right will not work as well and can miss up display as well.jim
Jul 17, 2011 | MSI H67MA-E45 LGA 1155 Intel H67 HDMI SATA...
My GA-H55N-USB3 powers on, three leds on (green, yellow, red) no beeps, no boot...case power light is sold for a few seconds, then flashes. ideas?
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 28, 2010 | Gigabyte GAH55NUSB3 LGA1156 Dual DDR31666...
Gigabyte GAH67MAUSB3B3 Motherboard Intel Core Socket 1155 Intel H67 mATX HDMI RAID SATA LAN (rev Logo
76 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
