Question about Mio Move SD Pedometer
Mio move SD pedometer how to change battery?
Where is the battery? How do I open this pedometer to see if it has one? Does it ship with a battery inside?
Why does my pedometer goes into sleep mode ewhen I stop and wont go back on when I start walking again. What do I havwe to do to get it started again?
This pedometer is programmed to go to sleep for a couple of reasons.
  1. To save battery life.
  2. To not inadvertently add steps to jostles or shakes. This pedometer has been programmed to only start counting steps at your 10th step from the sleep mode. This is to help with the accracy of the device.
May 08, 2014 | Ozeri 4x3motion Digital Pocket 3D...
Instructions for Eddie Bauer pedometer
How do I reset the Distance Pedometer?
Jan 12, 2014 | MIO Step 1 Pedometer Pink
How do you change the battery on the Sportline, fitness pedometer 360?
The battery hatch is at the bottom of the pedometer. Just slide the hatch open with your fingers and then pry battery out. Put in the new battery in the same orientation (positive up on most). I find shaking the pedometer works to get the battery to fall out. If my fingers don't move the hatch, I use a small flat blade screwdrivers.
I hope this helps.
(on my pedometer (a similar model) the hatch is on the back with a slot to slide in a finger nail and wraps partway around the hinge)
Aug 08, 2010 | Sportline 15 Function Total Fitness...
Change state on mio c220
goto main menu, click address, on the upper right button click change state...and select the new state..make sure that you have the SD card inserted for internal memory contains only 4 states, while SD card has 46 states. Thank you.
Apr 25, 2009 | Mitac Mio C220 GPS Receiver
Mio p550 not recocnized sd cards
Try this : Open your device ( it have 5 screws). Inside next to the sd card reader are two metallic sponges. Take them off ( they are glued on some electronic parts and it's shorting the circuits)
Mar 13, 2009 | Mitac Mio P550 GPS Receiver
Mio c220s canadian version
I would thnik you could download the US maps from a US cd that came with their unit to an SD card.
The C220 for the US comes with 4 states on the GPS and the rest on an SD card that is in the side of the unit
I downloaded the 46 maps form my cd to a 1GB SD card that I put in a sot on my computer.
http://service.mio-tech.com/M0100/MainFrame.aspx
Oct 02, 2008 | Mitac Mio P550 GPS Receiver
I have a Mio C220 that does not power on even though battery is charged. Will not work off of battery or plugged into cigarette lighter. Bought it in Nov. 07 but have lost box, receipt, software, and all...
Mio wants people to know, especially the folks who recently bought the Mio C220, that you need to put the SD card in the unit for it to work. The Mio C220 has the maps on the SD Card, and it seems that not everyone knows to put the SD card in the unit before firing it up. No SD card means no working GPS.
Mio Says:
1. Before you power on your C220, insert the SD Card firmly into the slot on the right side of the device
2. Once the SD card has been inserted into the device, power on your C220 by pressing and holding the power button for 10 seconds.
For More information check out the Mio GPS Page on the SD Card for Mio C220
Jun 21, 2008 | GPS
New battery
I know for the mio 168 you need a special torx screwdriver. They generally are supplied with a new battery. If not look on ebay for one.
Dec 20, 2007 | Mitac Mio 168 Pocket PC
Mio Move SD Pedometer Logo
66 people viewed this question
Top Mio Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Mio Exercise and Fitnes Expert? Answer questions, earn points and help others
