Question about Ariel Clearview - Pedometer with clear acrylic cover
How do you set an Ariel Clearview Pedometer ?
How do I change the time
Change the time on your pedometer this weekend ...
blog.walkingspree.com > Walkingspree
To change the time on your Omron USB Pedometer press SET and hold it ... AM and PM displayed on your pedometer or it will reset at noon instead of midnight.
[PDF]PEDOMETER - LuckyVitamin
www.luckyvitamin.com/.../Sportline%20Qlip%20Any-Wear%20Pedome...
8. SETTING THE PEDOMETER FUNCTIONS. SETTING TIME. 9. SETTING USER DATA. 10. OPERATING THE PEDOMETER. VIEWING PEDOMETER DATA. 11.
How to Set Up Your Pedometer - YouTube
? 1:51
https://www.youtube.com/watch?v=2Zgh9uDeA4w
Jan 31, 2016 | Exercise & Fitness
When does the clearview pedometer reset
I'm responding 'cuz my Clearview pedometer remains something of a mystery to me, too. So I apologize, right off, about the length and confusion in this procedure. Maybe someone will add a simpler, comprehensive list of commands.
W/o access to a user manual, here is what I've learned about it. Barbara, I didn't think it reset itself... maybe you can explain. I did find that when I hit the "reset" button on the back (to the left of the belt clip), it resets the Step (number taken), Mile (distance traveled), and Kcal (calories burned) to zero. One click for all-three together.
More SETTING steps: The menu is a vertical column to the right of the digital display (from top to bottom: Step, inch, LB, Mile, Kcal). As you scan down the menu, look for the teeny > arrow pointing at one of the functions. Normally the arrow skips from Step, to Mile, to Kcal. If you've been using it, and there are numbers in these fields, you can manually reset these to zero by pressing the "reset" button. Those 3 fields should now register "0" when you scan through the modes as before. I believe this does not reset your stride or weight settings.
These other 2 modes: inch (length of YOUR step), and LB (YOUR weight = this helps in calculating your calorie consumption... I think) were a bit tricky to reset to MY body. I managed to select those modes and enter my own data somewhat haphazardly, by simultaneously pressing the two buttons on the right (Mode, and Set); and then (sometimes, but not necessarily?) pressing the Set button alone. Either way, if you're lucky (!) you'll eventually get a blinking number and the arrow > indicating which field you're in: inch, or LB.
If it is the inch field, it will read 0, or something like 30 (your stride in inches). If you want to change it, press the SET button repeatedly (lower/right) to INCREASE the number in the field. Apparently you can't lower the number directly - if you instinctively press the upper/right button (MODE), it just closes the setting function.
So in order to set to the length of YOUR step, keep pressing (or you can hold it down) until you reach your stride length... it continues up to 120 inches (!!) before restarting at zero. I haven't figured out why it opens in inch, or in LB, but by randomly pressing both rt-hand buttons, I can eventually get into each of the two fields. The weight settings in LB also adjust only upward by pressing the SET button (that is, once you get the field to open). You may have to go to 150# (its max. setting) before you can begin at zero again. Last weird note: When I can't seem to get into these fields at all, I have had some success by pressing and HOLDING the SET button until the reading (usually 0, by then) blinks off and then on, once. Then you can proceed with the other steps.
Mar 24, 2014 | Ariel Premium Supply Clearview Pedometer
Is the Ariel Clearview Pedometer waterproof?
No it is not unfortunately a lot of pedometers and bands are not.
Do you know if the Fuelband is I have that one and am trying to see if I can swim with it
Aug 05, 2013 | Ariel Premium Supply Clearview Pedometer
Aldi Crane pedometer. Where can I get instructions?
[PDF]AU4-PF-6LA - Aldi
https://www.aldi.us/.../1.1.14_Crane_Heart_Rate_Monitor_Watch_...
ALDIFitness watch with speed and distance tracking. Pulse measuring without chest strap. Operating instructions. Item No.: AU4-PF-6LA/6LB. Issue: January 2014.
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic InstitutionGetting Started: Setting Up Your Pedometer. Starting your walking program is easy! Use these simple instructions to setup your pedometer and walk your way to ...
Tanita PD637 HANDHELD MOTION PEDOMETER Repair ...
www.dqrkc.com/support/p3651266-tanita_pd637...pedometer/page-4
Tanita PD637 HANDHELD MOTION PEDOMETER - Page 4 - Recent ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 308 Snapshot Pedometer Repair Questions ...
www.dqrkc.com/support/p3642406-sportline_308...pedometer/page-8
Sportline 308 Snapshot Pedometer - Page 8 - Recent Questions, ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 310 Qlip AnyWear Pedometer Repair Questions ...
www.dqrkc.com/support/p1496572-sportline...pedometer/page-8
Jul 31, 2013 | Exercise & Fitness
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
I cannot get my pedometer to count steps. I was able to set up the pedometer, I can work the stopwatch, but cannot get it to start counting steps.
Oct 06, 2010 | VIA Balance 50003 Via Step Pedometer...
Need set up manual
The instructions are generally the same for various models so here's the one for the pedometer plus..
www.yorksurvey.co.uk/documents/.../silva-pedometer(07-07-16).pdf
Oct 18, 2009 | Silva Exercise & Fitness
Reebok B 2 pedometer
1. Reset pedometer by pressing the reset button.
2. Find a long open place and take 20 steps with the pedometer
closed.
3. Check the number of steps the pedometer counted. It should be
between 19 and 21 steps.
4. If the count was not right, try to move the pedometer forward
(toward your belly button) or back (toward your hip) on your
waist.
5. Repeat this until you get the best count of your steps.
6. Once found, place your pedometer in this spot each day.
Apr 24, 2009 | RTO Reebok CS-1 Pedometer
Ariel Clearview - Pedometer with clear acrylic cover Logo
64 people viewed this question
Top Ariel Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Ariel Exercise and Fitnes Expert? Answer questions, earn points and help others
