Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Have john deere 50 kerosene space heater has fuel,new plug,
Starts by pushing the reset switch, runs for 20-30 seconds then shuts down with a loud click is equipted with a theromstart.I believe the eye is working, thanks
  • 92 Answers
If it trys to start when you turn the thermostate then thats not the problem, it has to be either the high heat limit control or the flame sensor. Mine did the same thing and I also thought the eye was working but as soon as I changed it the problem was solved. Pretty much all flame sensors are the same and you can get one from Mr. Heater for less than 3 bucks, same with the limit control.
Posted on Jan 23, 2009
Ok, when the truck starts it runs for a second, then it well turn off.. we start it again and it goes click, click.. we tried the battery's both are fine.
As far as I remember there are safteys in place to shut them down if there are turbo problems. to diagnose this you will need proper equiptment. I'll have to refer you to your local repair shop specializing in Deisels.
Oct 22, 2013 | 2003-2006 Ford F250 F350 SuperDuty 6.0...
I have a 94 caprice classic that wil crank but it wont turn on. It just got a new ignition and key for it and it still is doing this problem. it says press key fault and low oil pressure then it shuts off....
You vehicle is equipt with a fail safe switch incase your oil pressure is low it shuts off the fuel pump, More likely your oil pressure switch will need to be replaced,its 2011 relace the oil pressure switch more likely the sensor itself has failed,(oil breaks plastic after awhile,) make sure you have motor oil in the crankcase check the level,
May 04, 2011 | 1994 Chevrolet Caprice Classic
How do you reset the fuel pump shut off switch?
Doubt it is tripped
Push it in or down on it
Apr 07, 2011 | 1997 Ford Taurus
My heater starts and runs but then shuts off and I have to push the reset after a short cool down time before it will run again. I replaced the nozel, cleaned the photo eye, set the pump preasure, replaced...
In case you have misplaced your Owners Manual here is a link to where you can find it.
http://www.desatech.com/constructionheaters.htm
Where it' says Construction Heaters, open that and scroll down until you find the Model Number of your heater. Click on that Model Number and it will bring up the Owners Manual and you can download and print it. It has an extensive troubleshooting guide, that should help you.
Apr 04, 2011 | Reddy Heating & Cooling
I dont have the software that shows on screen when starting the WiFI or blutooth or lowdspeeker etc.
Hi
to activate the wifi switch it is i believe it is down of the left front of the laptop actually on the front of the laptop itself and normally a slide switch which needs to be pushed over to the right before it will activate
loud speaker icon depending on which operating system your running
if you are on windows 7 look over to the bottom right handof your screen if you cant see the audio
icon that looks like a loud speaker
can you see a upward facing arror
if so click on that arrow then click customize then go find the volume icon and click show icon
and notification
if on xp try this
start
settings/control panel
audio/sound
somewhere in there you should be able to tell it to show in taskbar
good luck
Feb 27, 2011 | Acer Aspire One PC Notebook
Torpedo kerosene heater shuts off after 15 seconds, have to push reset and it starts again, what's the problem?
Does it light? If it does it could be the electric eye that sees the flame and keeps the unit running. It is either dirty or bad. remove the eye and clean it. It pulls straight out and has two prongs on it. Does not matter how it goes back in. It is just a switch. Replace and try again. If it still does not light replace the eye.
If you cleaned the eye and or replaced it and it still does not work there are a few more things to check...
  • Not gtting enough fuel. Check the filter. Usually a small in line filter.
  • It also could be the transformer is getting weak. The transformer produces 10,000 volts between the two electrodes that keeps the heater running. I would only change the transformer if everything else checks out.
  • The electrodes may also need adjusted.
  • The nozzle also may not be atomizing the fuel properly to keep the unit running. I recommend changing it at least once a year depending on the use.
There are some good video on YouTube that will give you some great troubleshooting ideas.
Feb 21, 2011 | Heating & Cooling
The car will not start. My husband checked the
THIUS CAR MAY BE EQUIPT WITH A FUEL SHUT OFF SWITCH WICH IS LOCATED EITHER IN THE TRUNK ON THE INSIDE OF THE FENDER ,PULL THE CARPET AWAY AND YOU'LL SEE IT OR IT IS LOCATED IN THE PASSANGER SIDE KICK PANNELL UP FRONT ALL THE WAY TO THE RIGHT, RITE IN FRONT OF THE PASSANGER SIDE DOOR. MAKE SURE THE RED BUTTON IS PUSHED ALL THE WAY IN IF NOT PUSH IT IN SOME OF THEESE FORD PRODUTS ALL IT TAKES IS FOR SOMEONE TO KICK THE BUMPER REAL HARD TO MAKE IT POP
Jan 08, 2010 | 1992 Mercury Topaz
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
265 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
