Question about Lakewood (5500) Oil Filled Radiator Heater
How do I remove control panel on Lakewood oil-filled heater
SOURCE: Lakewood oil filled heater model 5600/7 won't turn on.
I went to buy a new oil filled heater because mine was blowing the breaker. After I bought two, I heard the sales rep telling a customer to store the heater on it's side or upside down or give it a good shake to loosen the oil from the bottom. So, I went home and tried this...it may take a couple of times before it stops blowing the breaker, but it works.
Posted on Jul 07, 2009
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
SOURCE: The Lakewood 5500 oil-filled heater has stopped
Similar problem here. But in my case, it was a blown fuse. There's an in-line fuse on the internal wiring of the heater. Take the control-side off (remove the bottom grey plastic bracket, then remove a sheet metal screw, then slide the whole assembly down off of the radiator). Where the elements go into the reservoir at the bottom of the radiator, the white wire should have an inline fuse connected to it. It will probably be covered with what looks like heat-shrink tubing. Snip, snip, and replace.
Posted on Jan 11, 2010
  • 3 Answers
SOURCE: my lakewood oil filled heater model 5600/7 just
The reason that it stopped is an open circuit. It is probably a blown thermal fuse. However, it could be any of the following if that is not the problem:
bad switch, broken or disconnected wire, burned open heater element, bad connections between terminals and wires, or between wire connectors and the wires within them.
If you take it apart, you will find the heat sensitive thermal fuse device under the heating elements, near the bottom of the unit. If the thermal fuse is good, it will appear as a short to an ohmmeter (zero ohms). If it is failed, it will appear as an open (infinite ohms).
The thermal fuse device can be replaced. Here is where to get one:
http://www.goodmans.net/get_list_632_2.htm
The thermal fuse may be this one, but check the temperature indication on yours first: Item#: TH-TF167C
Good luck.
Posted on May 10, 2010
  • 3 Answers
SOURCE: Need a thermal cutoff for our Lakewood 5500
We have these heaters and haven't had a fuse fail yet. I think it's because after the first time I got that crackling sound after moving it while it was on, I stopped doing that, and only move it with the power off, and wait two minutes before restarting it, so the oil can resettle.
However, the thermostats are now failing. Anyone know if this part is available?
Posted on May 14, 2010
KSD301
Try Grainger - snap disc controls.
Also, see my post, in response to "The heater does not work when switched on I have", under this same topic, 'Problem with: Lakewood Oil-Filled Electric Radiator Heater'.
Nov 07, 2012 | Lakewood Oil-Filled Electric Radiator...
I need a thermostat control for a Lakewood oil filled heater model 5101
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Feb 13, 2011 | Lakewood 5101 Oil Filled Radiator Heater
Lakewood oil filled radiator heater repacement switch
Here is a tip about space heaters that will also help you...
heatman101
Jan 26, 2011 | Lakewood Oil-Filled Electric Radiator...
My lakewood oil-filled radiator heater has a smell of oil? or something. What is it and is it dangerous. Could it be electrical?
The heater is filled with oil and it is leaking....you will need to dispose of it and buy a new one... it is not repairable...
heatman101
Jan 04, 2011 | Lakewood Oil-Filled Electric Radiator...
Lakewood (5500) Oil Filled Radiator Heater Logo
167 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
