Question about Home Security
Allister garage door opener won't turn off
The light doesn't turn off automatically.
  • 244 Answers
SOURCE: GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Posted on Jan 15, 2009
  • 118 Answers
SOURCE: garage door won't open
You probably have a broken spring on your door
Posted on Jan 18, 2009
  • 7 Answers
SOURCE: After opening, my automatic garage door creeps back down a bit
There is a sensitivity switch for both directions, open and close. If you access the garage door opener in the ceiling, you will see two adjustment screws for calibrating these. I would highly recommend following the instructions in your manual, as these are life safety adjustments! Your sensitivity for closing the door is adjusted to the positive. You just need to back it off a little. Place a 2x4 on the floor of the garage where the door comes down. and when the door hits the 2x4, it should automatically come back up. If not, you adjusted it too far. Hope this helps. and remember, check the manual for your specific adjustment procedures.
Posted on Mar 13, 2009
  • 3197 Answers
SOURCE: garage door will not open manually or automatically/normally
The color of the sensors is normal and have nothing to do with your problem. If you cannot raise the door manually and it is released from the opener then you have a door problem. If you mean the door won't open and you cannot get into the garage to release the opener then you are going to have to call a door technician for help. He will get in.
Posted on Feb 08, 2010
  • 3197 Answers
SOURCE: I have liftmaster professional garage door opener.
If your sensors are not pointed at one another the light on one of them will go out. Tweak them a bit. If you cannot get the light to come on then your sensors are bad.
Posted on Oct 25, 2010
2005 Pontiac Grand Prix front left turn signal went out, I replaced the bulb and the light comes on but the turn signal still doesn't work. If I have the lights sent on automatic the right parking
Hey I literally just today had the same problem, put a new bulb in the light was on but did not blink!!!! SUPER EASY SOLUTION, you simply have the bulb in too far. I gently pulled mine out a tiny bit and it started working fine... guarantee that's all that's happening to you!!!
Jan 25, 2013 | 2005 Pontiac Grand Prix
1988 Trans Am will not start when ignition is turned all the way.
Take a test light to the small wire on the starter and have someone turn it to the start position. If the light lights up and the engine doesn't turn over, I would suspect the starter itself. If the test light doesn't light, try it in neutral and repeat test. If it still doesn't light up, it may be the PRNDL switch or the ignition switch itself.
Sep 22, 2012 | 1988 Pontiac Firebird
Lift master 91LM
Won't work doesn't give us much to go on. Does it work with the wall control?
Jun 28, 2012 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
43 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
