Question about Mitsubishi MSH09TW Air Conditioner
Aircon wont turn on. Reset remote switched power off at Main
  • 8,220 Answers
Small fuse located in control panel blown most likely. Check it.It is hidden from view. Control must be removed to get to it. That is all.
Posted on Jan 23, 2009
Lg heatpump 6711a20003t - remote not switching aircon on,batteries good - also pressed reset button, still not working
Gee info on your LG is quite scarce!
I'm curious to know if you can MANUALLY turn it on?
It may be your Remote is defective? Here is a Link that MAY be helpful and MAY be just the Remote you need? No promises!
Universal remote control Airco 42530
Dec 24, 2017 | LG Heating & Cooling
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
YKR-K/002E cant switch it off with remote?
Make sure the batteries in the remote are good. Reset the aircon and the remote and try again. If not working, need to be fixed.
There may be a switch around the outdoor unit of the aircond for switch off.
Feb 25, 2014 | Heating & Cooling
Panasonic inverter aircon R410 A goes to timer all the time
You have to use the remote in service mode to find the error code. Hold the 'check' button in with a paperclip for about 5 seconds and "--" will be displayed on the remote. Press timer up or down will change the error code displayed. When you hear the main unit start beeping quickly for about 4 seconds, that is your error.
Nov 03, 2017 | Panasonic Heating & Cooling
Need a conia airconditer remote control here in Australia. We have 2 split systems that use the same remote. Models CA 24003 & CA 3003. Conia have gone bust here and we can't get a replacement remote....
i had the same problem and i managed to find a universal remote control from JARCAR Electronics. Model of the remote: Digitech AR-1729. It doesn't list Conia as compatible but I managed to gain control of the aircon using the code: 291. For some reason when you press the power button on the remote, it's like your double pressing the on button so the aircon switches on and off quickly. You need to press the power button on the remote quickly and move it from reception before it powers down the unit again. At least I have control of the aircon again and I don't have to put up with these humid hot days in melbourne... Good Luck.
Jan 01, 2010 | Heating & Cooling
I have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Nov 14, 2009 | Heating & Cooling
Aircon wont turn on
well check ur batteries in ur remote control unit and replace them with new ones instruction to do this u will find in ur user guide......
Mar 07, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Timer green light flashing when turned on but aircon isn't workn
reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Jan 31, 2009 | Heating & Cooling
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Mitsubishi MSH09TW Air Conditioner Logo
260 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
