Question about GPX KCL8807DT TV/DVD Combo
Unsupportive mode adding hdmi
The HDMI signal says "unsupport" What does that mean?
Normally this is a problem with the HDMI cable. It is sending a garbled signal for some reason (could be a bad end connector or a broken wire in the cable) and the TV does not recognize it. The simple way to fix this is by replacing the HDMI cable. Answered from experience as I had this happen about a month ago.
HDMI signal says unsupport Google Search
Jan 01, 2017 | Televison & Video
Fire tv stick unsupport
well there's your first problem right there !! fire sticks plug into a USB port not a hdmi port if your tv doesn't have a USB port then its not for using with a firestick
Oct 20, 2016 | Televison & Video
HDMI "unsupported" on konka tv
Xbox signals are not contactable with this Konka TV inputs.
Dec 19, 2012 | Televison & Video
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
I have a 22" Westinghouse
Change the settings on your HDMI output to 720 progressive for resolution. The tv likely cannot handle the 1080 resolution, or the tv can only use interlaced (1080i or 720i) format.
Aug 21, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
I can not play my PS3 on HDMI "unsupported mode".
While turning the PS3 on from standby, hold down the power button until the unit beeps twice (it'll beep once right away, and again maybe 5-10 seconds later). That should reset the video output of the unit back to default, and you can go from there picking supported resolutions.
Jan 10, 2010 | Insignia NS-LTDVD19-09 LCD TV
Hi, i have a flx-2211b element electronics tv and I have a xbox 360 hooked up to it through a HDMI cable but the tv says unsupported mode. what do i do to fix it?
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
Jan 07, 2010 | Element Electronics FLX2211B 22 in. LCD TV
Keep getting unsupported mode message after hooking up xbox360 using hdmi cable. can anyone tell me how to fix this.
It is complaining because it cannot support the resolution thaat the xbox is feeding it, what is the TV maximum resolution it can display?
Dec 13, 2009 | Televison & Video
When i plug in xbox to hdmi input it reads unsupported mode
The X-Box will not work on the HDMI input on that model. Either use the Component input or the Composit input.
Jul 01, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
GPX KCL8807DT TV/DVD Combo Logo
32 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
