Question about Viking Stove / Oven / Range Dual Thermal Gas Valve - PB010084
Viking model VGDO271ss does not ignite. - Viking Stove / Oven / Range Dual Thermal Gas Valve - PB010084
HAVE A VIKING MODEL NUMBER VGRT360 THEE IGNITER ARE STILL TRYING TO LIGHT AFTER BURNER IS LIT.
Hi ghughes7,
Moisture or water is shorting out your ignitors. Please follow my below Tip on repairing the problem:
GAS COOKTOP CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 05, 2011 | Viking VGRT360-6B 36 in. Gas Cooktop
I hav a Viking professional. Only one burner ignites.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Mar 18, 2010 | Viking 42 in. Professional Series...
My VIKING 31" VGSU 101 GAS COOKTOP. All 4 burners can't ignite .If I light it will work
I have the exact same problem, same model. Read the instructions on this website for replacing the ignitors...looks complicated, also generic to all Viking cooktops. Let's see what we response we get.
Oct 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking 6 burner range that keeps clicking after ignition
Spark ignition sparks until the flame starts. The flame ionizes the air between the igniter plug and the burner causing the small current to flow between the igniter and the burner. This shuts off sparking. But if there is a gap such as in the spark igniter under the porcelain, technically there still is a gap that the current has to jump and thus the stove keeps sparking. In my case changing the offending igniter plug fixed the problem.
Jul 05, 2009 | Viking VGSC366-6B Gas Kitchen Range
Multiple sparks when igniting one burner
have a 1997 model 2470 viking pop up camper , has a shower in stalled where does the used water come out ??
Jun 19, 2009 | Viking VGIC305-4B Gas Kitchen Range
Ignitor sometimes clicks, sometime not
You will need the ignition bird located il under the cooktop
Mar 28, 2017 | Kitchen Ranges
Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Jun 03, 2008 | Cooktops
Viking Stove / Oven / Range Dual Thermal Gas Valve - PB010084 Logo
43 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
