Question about Epson PowerLite® 6100I LCD Projector
Horizontal red line on screen from epson projector
I am getting a red haze line across top of screen about 2 inches thick. I replaced the lamp and that did not help. Any idea what the problem is and how expensive to fix?
    New Friend:
Fix pink and blue line/band on Epson projector
https://sites.google.com/site/troyinphoenix/
Posted on Oct 23, 2015
  • Troy Gibbs
    Troy Gibbs Apr 22, 2016
    Hi! I added an update to the instructions. Use epoxy to hold the lens in place. :)
5 Suggested Answers
Marrie
  • 563 Answers
SOURCE: yellow haze across top of screen
Hi there
This is probably a LCD that needs replacement , no easy fixes unfortunately !
Best would be to get it checked out by a Pro.
Posted on Sep 26, 2008
zabolyx
  • 38 Answers
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
  • 8909 Answers
SOURCE: My Epson EMP-1815 Projector displays
If you understand the requirement of specialist lighting and how to handle the lamp, the cheaper option will be fine.
Make certain you rebuild the light box exactly as you took it apart.
Use a camera to take photos.
Posted on Jan 04, 2011
caroldon
  • 17130 Answers
SOURCE: red haze at bottom of screen
Shut down the projector and allow time to cool before the lamp is taken out to be examined for any dis-coloration. If so the lamp needs to be replaced, try to test using a leased lamp to confirm Also check for shift in the alignment of the lamp settings and also the Lamp alignment.
Posted on Dec 15, 2011
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
My Samsung tv has thick horizontal line across top of screen
Check the LVDS cable that connects its T'Con board to display panel for any loose fitting at the both end of its sockets. Re-seat them once and check. This is not a problem with any capacitors. If you wish to get more details, check the site linked here. It has screen-shots to some faulty screens to LCD TVs. Compare them to that of your TVs' and make sure. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 02, 2013 | Televison & Video
Red haze at bottom of screen
Dec 15, 2011 | Epson PowerLite Home Cinema 8500UB...
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
Jun 26, 2017 | Mitsubishi WD62527 62 in. LCD HDTV
Purple band at top of tv screen
Please make sure you have the Lamp seated properly in the set. If you purchased just the lamp without the basket make sure it is Flush against the front of the lamp basket. The light path is being obstructed or not aimed properly. Let me know, hope this helps.
Feb 03, 2009 | Sony KDF46E2000 46" Projection HDTV
Red line across screen on a Sony kdf42e2000
OH YES, IS THE OPTICAL UNIT BLOCK BAD, THE PART # IS A-1212387-A
Nov 25, 2008 | Sony KDF-E55A20 55 in. LCD Television
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Epson PowerLite® 6100I LCD Projector Logo
2,943 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
