Question about Whirlpool Kitchen Ranges
I have a Whirlpool electric range modle # rf365bxvw the indicator lights come on but the burners or the oven wont heat up
the dr
  • 447 Answers
SOURCE: problem with electric range
Most likely the switch has welded closed
Posted on Sep 28, 2007
  • 3422 Answers
SOURCE: whirlpool Standard Cleaning Electric Rang Model RF315PXKQ
hi,
Can you please tell me if you have replaced the thermostat?If not then please do that.
Waiting for your reply.
Posted on Feb 24, 2008
huuum
  • 750 Answers
SOURCE: whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Huuum
Posted on Oct 03, 2008
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Posted on May 30, 2009
Whirlpool electric range oven broiler not working
Hello. This is a common failure for this range. Replace part number
9762215, price varies but about $100 average.
Apr 07, 2014 | Kitchen Ranges
Whirlpool Standard Cleaning Electric Rang Model RF315PXKQ
hi,
Feb 24, 2008 | Whirlpool RF369LXPQ Electric Kitchen Range
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
Whirlpool supercapacity 465 gas oven will not heat up all of a sudden
Does the igniter glow white hot? What is the complete model number?
Feb 13, 2013 | Kitchen Ranges
Heating elements on whirlpool electric range do not work
They may just be loose,try push the heating element in to socket,Or remove and check ends,may need cleaning to get good connection.
Dec 25, 2012 | Whirlpool Kitchen Ranges
Heating elements
I have a Whirlpool super capacity 465, the surface light for the burners comes on, the burners don't heat up, nor does the oven,(the light that says oven is on does not light up). I checked the main circuit breaker, that works. Are there any fuses in the range that would need to be replaced?
Thank-You,maddie
Feb 01, 2009 | Whirlpool GR460 Electric Kitchen Range
Oven and lights stopped working
is it the indicator lights at the top or just everything in the oven that is not working??
If it is just the light in the oven and the oven not heating then you are having a problem with your control board.
Jan 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
Kitchen Ranges Logo
48 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
