Question about Maytag MER5550 Electric Kitchen Range
Oven turns off and displayes F2,F3,and sometimes F4.
The oven seems to heat up fine. After its been on for a while it displays a F2 fault and turns itself off.It can be turned back on but faults every couple of minutes. It's not over heating, a temperature guage placed in the oven shows it maintaining the setpoint. Thanks for any help.
    Scholar:
  • 76 Answers
5550 The error code ?F2? will be displayed along with a beeping sound if the ERC (Electronic Range Control) or ?clock? senses a runaway heat condition during the ?cook? or the ?clean? modes. It could be caused by the oven temperature sensor, by the ERC or by the wire harness between the oven temperature sensor and the ERC. If the error code ?F2? is displayed in the ?cook? or ?clean? modes only, then the problem is a bad oven temperature sensor or its wire harness. If the error code ?F2? is displayed in the time of the day mode also, then most likely a problem is the bad ERC. The access to the oven temperature sensor plug and the wires is from the back only. You have to pull the oven out of the wall (if it?s free standing) or remove it from the cabinet (if it?s built in). Disconnect the power and remove the rear cover. Check the resistance across the oven temperature sensor. It is supposed to be about 1100 Ohms at room temperature. If the resistance is incorrect, the oven temperature sensor is bad and needs to be replaced. If not, check all the wires from the oven temperature sensor to the ERC. Replace all wire nuts if any. If it is not the sensor and wires, you have to replace the ERC. To get the right replacement part just click on the link http://tinyurl.com/34ujtl , then type the model number of your oven in the search box, click on the ?search? button and in the new window type the word ?sensor? or the word ?clock? in the ?search by keyword? box and click the ?search? button. Gendos post back...
Posted on Jul 07, 2007
  • Gennadiy Kagan Jul 07, 2007
    Due to conflict between different editing software the double quote marks in my previous article have been replaced with the question marks.
    Gendos
I have a turbo chef oven, I have F1 and F5 error on the display! Any suggestion?
Troubleshooting...
Faults Requiring Service Call
If one of the below faults appears on the oven display, call 800-90TURBO (88726) or +1 214-379-6000.
* F1: Blower
* F2: Low Temp
* F3: Mag Curr
* F4: Monitor
* F5: Mag Temp
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 01, 2011 | TurboChef TORNADO Electric Oven
Range displays code of F4 and stops working
F4 Oven temperature sensor (RTD) shorted Replace Oven temperature sensor (RTD)
The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
Hope helps.
Jun 14, 2011 | KitchenAid Kitchen Ranges
Fault codes F1 and F2
Just two work there:
1.- Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
2.- Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Parts replacement coudl look in www.repairclinic.com
Hope helps.
May 02, 2011 | Magic Chef Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    The oven isn't working and it says FO in red letters
    GE / Hotpoint / RCA
    Oven Fault Codes
    Display Condition Remedy
    F0 & F1 Failed Thermistor Control Replace ERC
    F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
    F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
    F4 Shorted wire or Sensor locate short and correct it
    F7-A Function pad button stuck Clean and unstick
    F7-B Bad Clock Replace Clock
    F8 Electrical component failure Replace ERC
    F9 Program with door circuit Check wiring
    Frigidaire / Westinghouse / Tappan / Gibson
    Oven Fault Codes
    F0 & F1 EOC failure Replace EOC
    F2 Oven over heat Defective Sensor or EOC
    F3 Oven Sensor Open Replace Sensor
    F5 EOC failure Replace EOC
    F6 EOC failure Replace EOC
    F7 EOC failure Replace EOC
    Maytag / MAYCOR / Magic Chef / Jennair / Admiral
    Oven Fault Codes
    F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
    F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
    F2 Oven over heat defective Relay Board or (if present) or defective Sensor
    F4 Shorted wire or Sensor locate short and correct it or replace Sensor
    F5 Hardware, safety circuits disagree Replace Clock
    F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
    F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
    F8 A/D Warning Replace Clock
    F9 Door Lock Warning Check door lock circuit or Replace Clock
    Amana / Caloric
    Oven Fault Codes
    Type with display - glass link ERC
    F0 No Safety Signal Replace adapter board
    F1 No Safety Signal Replace ERC
    F2 Oven over heat Replace defective Sensor
    F7 Shorted Touch Panel Replace Glass Panel
    F9 Door Latch Error Check latch
    FF Lock Error Check switch and motor
    ERC III - Relay board with separate board/push buttons
    F0 Shorted Push Pad Replace Push Pad
    F1 Defective ERC Replace ERC
    F3 Oven Sensor Open Check/Replace Sensor
    F5 Defective ERC Replace ERC
    F6 Defective ERC Replace ERC
    F7 Shorted or sticking button Clean button or replace touch pad
    F8 Defective ERC Replace ERC
    The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
    Whirlpool / KitchenAid / Roper
    Oven Fault Codes
    Ovens with 4 digit displays
    F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
    F1-E1 Defective ERC Replace ERC
    F2-E0 Shorted Keypad Replace Keypad
    F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
    F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
    F3-E2 Oven over heat Replace Sensor
    F3-E3 Cleaning Temp over heat Replace Sensor
    F5-E0 Door Error Check Door
    F5-E1 Door Latch Check Latch
    F5-E2 Door Switch Check Switch
    Ovens with 2 Digit Displays
    F0 Defective ERC Replace ERC
    F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
    F7 Shorted or sticking button Clean button or replace ERC
    F9 Door Latch Error Check latch and latch circuit
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Dec 18, 2009 | Ovens
    Controlpanel flashes f 3
    You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
    Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    F7 error code- what does this mean?
    Oven Fault Codes
    May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
    GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
    F3 is Open oven temperature sensor circuit.
    F4 Shorted oven temperature sensor circuit .
    F7 Component failure.
    To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
    Oct 28, 2008 | GE JRP15 Electric Single Oven
    Maytag MER5550 Electric Kitchen Range Logo
    379 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    gbob59
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
