My F9K1001v1 Belkin N150 can't link to TWC modem
I have tried countless time working on my own and with Techs from TWC to link my router to the modem without success. Nothing seems to work : I've disconnected the modem, waited 15 seconds and reconnected; then disconnectged earthnet cable from computer to the router for 15 seconds and reconnected; and disconnected router for 15 seconds and reconnected without success. What else can I do?
  • 16 Answers
SOURCE: Router Connectivity
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Posted on Aug 10, 2008
Joed911
  • 4338 Answers
SOURCE: I have a Linksys router and it really dosn't tell
Great !
But if you have trouble installing the cd, follow these instructions:
Router setup
You do not have to use the cd.
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Mar 14, 2009
SOURCE: My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Posted on Jul 21, 2009
SOURCE: My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Posted on Sep 15, 2009
bahratt
  • 561 Answers
SOURCE: My belkin N router flashes amber on my modem...all the time.
You may need to upgrade the firmware of the device. Please see setp by step instructions here: http://en-us-support.belkin.com/app/answers/detail/a_id/497/q/routers
Download your latest firmware from: http://en-us-support.belkin.com/app/answers/detail/a_id/306/kw/F5D8236-4/r_id/166
Posted on Jan 12, 2010
What is the username and password for the brighthouse ubee
You are able to access some of the modem/router settings using the credentials:
User Name - "user"
Password - "user"
Without the quotes, of course. This will not give you complete access, however, it will allow you to modify a fair amount (not in my opinion) of settings and view various modem/gateway information pages.
Unfortunately, Brighthouse (BHN) is on their game, when it comes to locking certain features/settings from being changed by the consumer. Time Warner Cable (TWC) sold select areas to BHN some time ago. TWC is a bit more open to user changes.
For example, TWC and BHN both supply the modem/router Ubee DDW3611. TWC's supplied unit's configuration can be accessed by the customer through the 'User' account and the 'Admin' account. BHN, on the other hand, only allows the customer to access the configuration through the 'User' account-which limits the available configuration options.
TWC units may be accessed through the 'Admin' account using the following credentials:
User Name - Last 8 characters of the Ubee Modem MAC Address
Password - c0nf1gur3m3
For example: If your Ubee Modem MAC Address is "1C:6D:CB:14:D6:4A"
Your 'Admin' credentials would be:
User Name - CB14D64A
It is very unlikely that the aforementioned credentials will work to log in to the 'Admin' account for BHN supplied units. But hey, its worth a shot. Right?
Hope this helps.
-James.
Aug 12, 2013 | Computers & Internet
Cannot connect to my belkin n150 model f9k1001v1 router
Yes. You need to modify the IP and DHCP scope on the second, so there are no IP conflicts.
Plus this setups a second LAN, and obviously a second network configuration if you are trying to use the same computer.
Nov 09, 2012 | Belkin Computers & Internet
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
How can i troubleshoot if the router is working properly? We have 2 computers at home: an iMac G5, and a Dell laptop. When the iMac is connected directly to the DSL modem, everything goes well....
well your question is so clear and i can easily isolate the problem...this is because the particular model router has some issues with some ISP's...this problem can be fixed for sure by updating the firmware of the router with a latest one...
you can download the latest release of the firmware for your model and version from the link given below...
http://en-us-support.belkin.com/app/answers/detail/a_id/523/p/365
try this your problem will get fixed...
Apr 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can not connect Xbox and computer to be online at the same time
is this a new belkin router... I suspect that the belkin has a firewall. or the windows box is trying to take the XBOX over...I am sure we can get through this
Aug 05, 2009 | Dynex Enhanced-G Wireless Broadband Router
My router just stopped working. The internet
There can be several causes for this:
1. Check for power to the router which can be lost because of a loose DC plug or bad power brick.
2. Check the DSL or cable modem if it is working properly and can get you on line if directly plugged into your PC.
3. If any of the above are ok, then your router has just died. Routers have a high rate of failure so I won't be surprised if this was the case with yours.
Jul 13, 2009 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Belkin F5D7230-4 not working anymore?
Well i think u r right, u must contact to Belkin support team (http://www.belkin.com/support/) or to from where u buy this. If router is in warranty period then u will get replacement.
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
