Question about Fisher and Paykel GWL11 Top Load Washer
Smart Drive - no power
I have lost all power to my F & P Smart drive machine. It stopped in the middle of a cycle. Any tips?
  • Dale Skewes Jul 10, 2007
    Here are some more details:
    I have been tinkering with the machine (GW709AU) in order to unblock the pump. I fixed the problem, but in the process (don't ask me how, it's a long story) disrupted the plug that supplies power to the pump underneath. When I found the machine wouldn't work I discovered the plug had moved. After I plugged it back in the machined worked fine for about a week. Now it doesn't work at all. I checked the plug supplying power to the pump again, but it seems fine.
    Hope you can help.
    Skewzyboy (Dale)
  • Dale Skewes Jul 17, 2007
    Thanks Catriver,
    I checked the resistance on the pump and valves. They are okay. The machine didn't reset itself, but I found an open fuse on the motor controller board. I closed the fuse with a fine wire. When I turned the machine on, the other fuse blew (in a big way), and one of the other components appears to be gone (a resister or capacitor - not sure). Anyway, it seems I need a new motor controller, but can I be sure that will fix the problem? How do I know what caused the fuse to go in the first place?
  • 725 Answers
To Check a Capacitor First check to see if the capacitor is bulging or changed in physical shape of any kind this is signs of a bad capacitor also check for oil may be leaking from it. With the capacitor unpluged use an Ohm meter set on OHMs scale, Rx1 you can check the terminals and the needle will jump upward and instantly fall back to zero. Reverse the leads of the meter and check it again. You will notice the same jump of the meter, and again fall back to zero. This will likely mean the capacitor is good. This check is for a shorted capacitor only, not a measurement of its capacitance, but will let you know if you have a bad capacitor. let me know..
Posted on Aug 25, 2007
    President:
  • 878 Answers
Dale, The pump is used as part of the power supply. If not connected the unit will appear dead. Check the pump resistance, should be 33 ohms. The pump has a thermal cut-out. If it's tripped, it should reset within 15 minutes. If it tripped, check for a blocked pump. Check for resistance from phase and nuetral to ground. This will identify if either the motor wiring harness or lid switch harness is shorting to the cabinet. Each water valve should ohm at 64ohms. If all this checks ok, then it's probably the motor controller. Catriver.
Posted on Jul 11, 2007
SOURCE:
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
May 27, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Our washer was in the middle of the spin cycle and I heard a loud crack sound and everything stopped and I can't even get power. We're thinking maybe it's the belt. One other problem; the water didn't...
Smart Drive washers do not have a belt... If you can't get power, you've most likely burnt out the motor controller board. This is probably due to another component failing...You should call a tech....To remove the water, remove the cone from the centre of the agitator, and undo the large wing nut inside the tube. This will let you remove the agitator and ladle out the water.....Good luck.....Nomess
May 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine stops and beeps every second. Tried various points in cycle. pump appears to work then stops. Its a smart drive excellence 7.5 kg
it sounds like your out of balance switch is open circult.out of balance switch is located under control module.test for continuity on switch.make sure power is turned off first.if u have problems reply 4 more help
Mar 16, 2010 | Fisher and Paykel Washing Machines
Washing machine stops in the middle of cycle
there is so many reason why your washing machine has stop in the middle of the cycle. i give you simple tips to solve your problem 1. check your main plug if that is in proper connection 2. check if its block out or what ever 3. check the swicth 4. check the load if its over loading 5. check the motor by smelling if its burn....... i hope my simple tips can solve your problem....
Jul 19, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F & P Kelvinator Smart Drive 708 - Faulty power switch and cycles
I have a smart drive 708 that will turn on but won't fill, any suggestions?
May 25, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Washing Machine Stopped Working
Hi Beth, sounds like you broke a belt. You can verify this by pulling the washer away from the wall and tipping it back to look underneith. Should have two belts, pump and drive. The part numbers are 211124 pump and 211125 drive. Catriver, post back.
Aug 02, 2006 | Maytag Dependable Care LAT9706
Fisher and Paykel GWL11 Top Load Washer Logo
172 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
