Question about Maytag MER6772 Gemini Electric Kitchen Range
Parts diagram mer6772 - Maytag MER6772 Gemini Electric Kitchen Range
Finish on burner stained and dulled on maytag gemini range
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MER6772
Select your correct model number from the site above and you can find the parts that are stained and dulled, and replace them with new ones.
You could also try using a cleaning solution to clear away the stains.
Mar 17, 2011 | Maytag MER6772 Gemini Electric Kitchen...
F1-2 prompt keeps beeping
"F1:2" is a Runaway Cook Lower Oven error. This indicates that the oven temperature sensor is defective and needs replaced. The following link explains how to replace an oven sensor on most ranges:
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
Replacement parts (if required) can be purchased at any of the following websites:
pcappliancerepair.com
searspartsdirect.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. The sensor is listed as item 7 under the "Oven" parts listing.
If you have any questions please post and let me know. I hope you find this information helpful.
Jun 22, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Why are the hot buttons under the suface of ceramic cook top always on?
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at http://appliancehelponline.com/infiniteswitchvideo.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Jun 08, 2010 | Maytag MER6772 Gemini Electric Kitchen...
I broke the glasstop of my stove. Can I replace
http://www.partselect.com/Maytag-Stove-Parts.htm
just typ in your model number, and find the part you want on the diagram. you can purchase it through them, too.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Problems with Maytag MER6772 Gemini Electric Kitchen Range
may tag gives 5yer worenty if not still under worant get rid of it
Apr 05, 2009 | Maytag MER6772 Gemini Electric Kitchen...
MER6772 front burner......is there a fuse that controlls the out
sounds some like you know a little about appliances.if power is leaving switch and burner not working.its your burner.take a look at wiring diagram it will show you the power path, use volt meter[looking for out put at switch],[the limiter that you see in wiring diagram is built into the burner and can not be replaced by its self]so if power leaving switch replace burner.hope that helps.God bless ,tom
Jan 06, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Dual Oven MER6772BCA
sounds like the broil elemnt in the upper oven is shorting itself out part number 74004106, probly 45 bucks. leave the circuit off adn replace it... the wire(s) leading to it are always live.theres a few screws across the top of the cavity holding it up
Apr 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini ELectric Stove
F9-3 code means the latch on the oven is faulty. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=MER6772BAQ&PartCategoryName=&Keywords=latch
Sep 17, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
19 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
