Question about Cooktops
How do you remove a Neff Cooker Ignition Transformer for T2163N1EU/02
I can see the ignition transformer and can get to it, but I don't know how to remove it from the base of the hob? Thanks for your help
SOURCE: Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Posted on Jan 06, 2008
Eddie Rentas
  • 59 Answers
SOURCE: hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
SOURCE: Neff Hob
Hold the power button for a few seconds
Posted on Nov 01, 2008
  • 222 Answers
SOURCE: Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Posted on Jan 11, 2009
SOURCE: Neff T4344 hob, need instruction manual???
Try http://bshappliancecare.com/Neff/customercare.html
You can download a PDF manual for the T4344
Regards
Jon Morgan
Posted on Feb 06, 2009
All lights and ignitors on my GE ZGU385N (Gas cooktop) stopped working all of a sudden. I checked the input voltage to the transformer and all looks fine so I know the issue is not with the outlet or power...
Disconnect power and set you meter to ohms. Check the both the line side and the low side of the the ****** for continuity. If you cannot get a reading from either side then that puppy is bad. More than likely that is gonna be it since everything quit. If it was the igniter box you might have weak spark etc. I thnk that transformer is your prob.
Sep 11, 2011 | General Electric Monogram® ZGU385NSMSS...
I don't know how to connect to the wall plug
I think that I would get an electrician if it isn't a straight forward plug
Jun 10, 2011 | Neff T1323 Electric Cooktop
Neff hobb, ignition continuously sparking
igniton control module is bad or one of the switches is arched together on the inside of the switch requireing if it were arched together you to buy a new switch if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliace situation Thanks again
Rick
Dec 14, 2010 | Neff Cooktops
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
Ignition on centre burner keeps tripping, how do I
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 25, 2010 | Neff 28 in. T2766 Gas Cooktop
Ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Feb 22, 2010 | Cooktops
Gas comes on but no fire comes out when knob turns on. must light manually
ur igniter is not working either the igniter wire or the transformer...igniter wire is in the buner base color white ceramic that the igniter wire..if is broken pelace it..check all the igniter wire...if no sound it is igniter transformer...its expensive to replase the igniter transformer.
Jan 13, 2010 | Cooktops
Neff Hob
Feb 16, 2008 | Neff 23 in. T1443 Electric Cooktop
Constant ignition clicking
try easing the knobs up slightly, they are just a push fit
Apr 21, 2007 | Neff 28 in. T2764 Gas Cooktop
Cooktops Logo
91 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
