Question about Samsung SGH-E900 Cellular Phone
My Samsung M520 slider screen goes white and freezes
Lately, when I slide my M520 up to use it, I will encounter a white screen and it takes a while for the screen to unfreeze. I cannot do anything with my phone when this happens. What, if anything, can I do to fix the problem?
  • 1 more comment
  • tgirl2203 Jan 23, 2009
    My phone does the same thing and has fuzzy lines through it at times too. I got this phone brand new 5 months ago to replace my LG Rumor that had the same problem.
  • Anonymous Feb 10, 2009
    I have the identical poblem.
  • sbaeraar Feb 10, 2009
    I also have the same prob. I bought a rumor a year and a half ago and I had to replace it, no lie, 10 times. Then I get the Samsung M520 to solve this problem and my phone tonight freaks out with lines and then fades into a white screen. I am calling Sprint's Insurance to get my phone swapped! It's rediculous!!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Posted on May 07, 2009
2 Suggested Answers
SOURCE: My Samsung M520 slider screen goes white and freezes
yeah i also have a samsung m520, and its rececntly been turining white then back to normal. Its really annoying. I got it replaced last year with the warranty but now, about a year later, it turns white again. I went to the Sprint store and they said the cord that connects the screen and slider is either cut off or damaged. I like never drop my phone or in water, and its sucksss...
and i thought Samsung was reliable.
Posted on Mar 05, 2010
I have an M520 that used to take great pictures - now lately the picture is distorted and seems to be all grainy/green. I've tried each of the options, resolutions, brightness controls, etc. Sometimes...
QUESTION:::::::::: I have an M520 that used to take great pictures - now lately the picture is distorted and seems to be all grainy/green. I\'ve tried each of the options, resolutions, brightness controls, etc. Sometimes (not every time) after I make a change to the brightness or resolution or white balance setting the picture goes back to normal - but not everytime. Most of the time it\'s just unusable because it\'s so distorted... almost like it\'s over exposed? I\'ve literally checked every setting available to no avail. I want to say it started happening after doing a firmware upgrade. Anyone else having that problem?
answer: i never knew the answer in exam also i cheated fron s 10's boy, the invigilator scolded me but i drank dew ans said daar kay aagey jit hay and continued my cheating program.
so u also cheat the solution of ur desk partener OR buy NOKIA 1100 its perfect 4u ********!!
Nov 11, 2010 | Samsung SPH-m520 Cell Phone
My M520 screen is completly white
ur display has gone..... service it in samsung service station
Apr 11, 2010 | Samsung SPH-m520 Cell Phone
My screen is white and will not change
Those slide up Samsung phones have always done the same thing to me.
Close it and let it go dark and then slide it up and/or turn it off and back(at least thats how i use to solve the problem.) on its just Samsung because I have had several and i swear they have all done the same exact thing!!!
Mar 03, 2010 | Samsung SPH-m520 Cell Phone
I just want to completely disassemble my phone. how do i do it?
Start by removing the battery and the four small Phillips-head screws around the battery. Next, remove the plate on the back of the phone, below the battery panel. The panel is stuck in place with sticky foam and might be hard to peel off. Then remove the two small phillips-head screws. Next use a tiny (glass repair kit) flat-head screwdriver to pry the two halves of the base apart at the seam.
This is where it gets tricky. Gently take each piece off one-by-one. But to separate the screen you have to slide it half way and hold it in place while you unplug the ribbon cable from the circuit board in the base of the phone. Then disconnect the arm from the slider and slide the phone open to remove the two screws behind the silver stickers on either side of the camera "shutter". Now pry the slider housing apart as with the base.
Oct 21, 2009 | Samsung SPH-m520 Cell Phone
Why does the screen on my Samsung M520 turn white?
the problem comes from the led film behind the screen. There is absolutly nothing you can do about it now. When you got your fingers all over the screen by sliding it, it starts to break. It isn't going to get better, probably only going to get worse. the only thing that you can do is buy anotherone im afraid
Jun 14, 2009 | Samsung SPH-m520 Cell Phone
White screen on my samsung rant
There is a fix. Ok so what you wanna do is power off your Samsung rant then you take out the battery and put it back in. After that you open to the slide pad and hold down the T and Y keys then power it on while still holding the 2 keys after the Samsung logo pops up then you can let go. Keep the slide keys open while it is powering on. You can close the slide pad when your screen shows up then it should be fixed. Well hope this works for you it worked for my moms phone when she was having this problem. Note: If your phone screen freezes or turns white again just redo the process.
Jun 03, 2009 | Samsung Rant Cell Phone
White Screen
Apr 23, 2009 | Samsung SPH-m520 Cell Phone
White screen driving me CRAZY!!!
The issue you are having deals with the "flex cable" connected to the motherboard of your phone to the LCD screen. This cable is very important, because it transfer pixels so that you can view your handset and operate it. Over excessive opening and close the slider, can wear in the flex cable to cause the white/garbled screen. It's not your fault, but the manufacturer and their effort to fail to make a device that can withstand excessive sliding. Check with your local service & repair store. If you do not have insurance, other options will be given you. Thanks. Hope this helps!
Mar 13, 2009 | Samsung SPH-m520 Cell Phone
Feb 12, 2009 | Cell Phones
Slide up, screen goes white but keys are active...
The strip that connects both the upper and lower slider is damaged ... replace it
Dec 11, 2008 | Nokia N80 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
224 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
