Question about Kenmore 43142 Front Load Washer
Kenmore - 43142 front load - leaking
Ok, got the screw out of the machine. Now the rubber door seal is leaking as well as from the hose. Need advice on how to fix the rubber door seal and stop the hose from leaking. Thank you.
  • Debra Troconis Jul 07, 2007
    It's the hose we took off that goes to the pump so we could try to find the screw. The rubber seal around the door wasn't leaking prior to all of this. I think just moving it around, tipping it, etc, dislocated the rubber seal. How do you put it back in place?
  • Anonymous Mar 13, 2014
    I have a leak and found the rubber hose to have a split in it
  • 5,911 Answers
Which hose are we talking about? If you're talking about the small rubber hose at the top center of the door seal, HOW is it leaking? Is there a hole in the hose? Is the door seal itself damaged? Let me know a little more so I can give you the proper advice.
Posted on Jul 07, 2007
  • Jeff Rockwell
    Jeff Rockwell Jul 08, 2007
    If you're talking about the drain pump hose, that's a fairly simple fix. If you removed the inlet side, you simply push it back over the inlet tube making sure it is on ALL the way. If I'm not mistaken, the plastic inlet tube has a slightly beveled shape. That is, it's wider at the end. You need to make sure you get the hose fitted over that tube correctly, and the clamp is properly seated all the way around or it won't seal. If you can't get the squeeze-type clamp on all the way, you can try using a standard screw on hose clamp.
    Now, depending on how the door seal is leaking, this could be an easy fix, or this could mean replacing the whole seal. The door boot has an inner and outer groove that it seats in. The outer seal around the door opening is just a matter of seating the rubber seal into the groove around the door all the way around. Sometimes the seal is glued on.
    Now, if the inner seal around the wash tub has come off, you will need to remove the console, door, door latch, and front of the washer to get to it properly. To do so, follow these steps:
    1. UNPLUG THE WASHER, FIRST.
    2. Remove the two screws holding the top of the machine on. They will be located in the rear of the washer. The top should slide back a bit, then lift off.
    3. Remove the dispenser tray and console. The console has a couple of screws holding it on. (Don't forget the one behind the dispenser tray). Take a small putty knife and gently slide it under the console just above the door and lift just slightly. This will release a plastic tab holding it on. The console should lift out from the bottom first, then off. Carefully lay the console out of the way on top of the washer. You DO NOT need to disconnect the wiring harness.
    4. Remove the lower kick panel.
    5. Remove the screws holding the door in place, and set the door aside. Be careful, it's made of glass.
    6. Carefully unseat the outer door seal ONLY, and push the rubber boot inside the machine door to expose the door casing opening.
    7. On the right hand side of the door, remove the three screws holding the door latch in place. With your free hand reach inside the casing and gently pull the door latch off the casing and move it out of the way. You can let the latch hang, but be gentle with the wires.
    8. Now that the casing is free of everything, there should be 2 screws on the top and 2 screws on the bottom holding it on. Remove the front of the machine and you will now have full access to the inner door seal on the tub.
    9. If the seal is not torn, you should be able to re-seat it. The inner seal fits into a groove all the way around the tub. There will either be a large band clamp holding it on, or (I think in your case) a large retaining spring. If it's just a band clamp, loosen the clamp first and slide it off, so you can check the seating of the rubber boot. Then slide the clamp back into place, making sure it is seated properly all the way around the seal. Then, tighten with a 7mm nut drive being careful not to over tighten.
    10. Now, the spring type, I'm afraid, is the trouble encountered with trying to get the door boot to go back on. It will take some muscle, and the effort of a couple more hands, to get it to go back on. Starting at the top, make sure the seal is seated properly all the way around, first. If the spring has come out, start at the top again and start working the spring back into the groove. At the 3 o'clock and 9 o'clock positions, you will need someone to hold tension on it by holding it in place. Then pull it straight down and snap it back into the groove around the bottom half of the seal. It may take some effort.
    I know this seems like a lot, but it should be fairly simple if you follow these steps. Good luck and let me know if this was helpful.
Leaking water
If the hose is ok and you need to check if the leaking coming from the seal of the rotating shaft you can check when you remove the cover behind the machine if it is ok check the rubber seal of the front door
Regards
Mar 31, 2014 | Maytag Neptune MAH5500B Front Load Washer
Water leaks with larger louds on kenmore front load eco
Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Feb 01, 2013 | Kenmore Washing Machines
The washing machine (front Load) leaks water
hello you may have an hole in the door seal check the rubber seal around the door if this is ok then check rubber hose on the pump
regards
shaun
Sep 01, 2010 | EuroTech EWF172 Front Load Washer
Rubber seal damaged. needs to be replaced kenmore model 970-c44052-00 How do I remove sides to get at it?
there is no need to remove the side to replace the door seal, just behind the door seal there is a spring clip undo this and fold the seal into the drum were you should see another spring clip undo that as well and the door seal comes out from the front through the hole in the door, to refit a new fold the seal till its inside out and fitted on the inner drum first fit the inner clip then pull it through the door hole and fit the outer spring clip out side the door
Dec 06, 2009 | Kenmore 43142 Front Load Washer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kemore HE is leaking when washer is filling up with water
OK, if this leak is coming from the front lower side of the door, this Will eb a door seal issue. make sure the seal isn't compromised by a small object that may have been jammed during the closing of the door. if this isn't the case, replace the faulty door seal.
Now, if this leak is coming from the the bottom back side of the unit. this will be a water valve issue. check the hoses that connect to the inlet valve. make sure the hoses are tightly screwed on there respective sections.
Jun 19, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Water leaking from bottom of door during wash cycle
this will more likely be your door seal open the door pull your seal so u can see inside and feel around as u look u will more than likely find a hole the water looks like it comes from somewhere else but it will be from the hole in the door seal seen this with hundreds of washers m8
Aug 26, 2007 | Kenmore 43142 Front Load Washer
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Kenmore 43142 Front Load Washer Logo
302 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
