Question about NEC MultiSync 1525X 15" LCD Monitor
What cable do I buy
I was given an NEC MultiSync 1525X 15" LCD monitor. All that came with it is the power cord. What cable do I need to buy to connect it to my computer?
    President:
  • 1,179 Answers
If it is a dvi monitor then you would need a dvi cable. VGA monitor would need a VGA cable. HDMI monitor would need a hdmi cable. If it is compatible with both dvi & vga and your video card has a dvi output then dvi is a better quality than vga. You can purchase the cable online at a store like cables2go. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 23, 2009
Why does a monitoring keep going off?
you forgot to say, screen dark? and power light off.
does the OSD work? Push button that pops up the OSD screen for bightness, does that work>
\can be one of 4 things. 100 % dead.
try it on another PC>
bad power cord
bad video cable.
bad LCD
bad PC, bad Video card in PC or some game using an illegal video card mode.
try another PC and see if the LCD works there.
easy huh?
Sep 30, 2013 | NEC MultiSync 1550V 15" LCD Monitor
Nec multisync 1525x need user manual. annoying menu keeps poping up on screen. any ideas ?
Here is the link for an Multisync 1525x
http://www.necdisplay.com/cms/documents/UserManuals/l1525Xg.pdf
Feb 25, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
Nec multisync lcd 2080ux no raster no power indicator light.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
Nov 06, 2008 | Computers & Internet
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Jun 02, 2008 | NEC MultiSync 1550V 15" LCD Monitor
Mounting a NEC MultiSync LCD 1560
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 22, 2007 | NEC 1560V+ 15" Flat Panel LCD Monitor
Computers & Internet Logo
228 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
