Question about Acer Aspire™ T180 PC Desktop
Opening side panel of acer aspire t180
I CANNOT GET THE SIDE PANEL OFF MY ACER ASPIRE T180
I WANT TO INSTALL A SECOND HARD DRIVE BUT CANT GET INTO THE CASE !!
I HAVE TAKEN THE TWO SCREWS OUT BUT IT REFUSES TO BUDGE ARE THERE ANY OTHER SCREWS HOLDING IT ??
  • budger9999 Feb 14, 2009
    I try and try. The panel won't budge. Help!!!
    Problem Solver:
  • 6 Answers
You have done half the work toward the solution by removing the thumbscrews. The other half involves sliding a spring-loaded lever above the lower thumbscrew toward the bottom of the case. While the lever is slid toward the case bottom, push on the side panel in the same direction as the screws, i.e. toward the rear of the case. The side panel should slide just slightly, allowing you to then lift it off to access the inside. Note that when replacing the side panel, follow the above steps in reverse order.
When replacing the side panel, note that if the panel is not correctly replaced, the thumbscrews will not be able to be installed as the lock lever will not be set properly.
Posted on May 28, 2009
    Problem Solver:
  • 14 Answers
First take the Desktop and place is face down with the power fan facing towards the ground.
Then unscrew the two screws and place both hands on the entire side panel and press down and slide towards the right, this should work.
Posted on Jan 23, 2009
Can't get the side panel off my acer aspire ast 180-UD360A
Hi I was suppose to provide you the instruction however it would be better if you will see the images including steps on how to remove the side panel of your tower..This website will help you a lot ..
http://global-download.acer.com/Step5.aspx?Step1=Desktop&Step2=Aspire&Step3=Aspire%20T180&BC=Acer&Category=Document
Nov 17, 2011 | Acer Aspire™ T180 PC Desktop
I have an acer aspire t180-oa7z. i want to put a new hard drive in. my current hard drive 80gb SATA. what hard drive would you recommend?
For your current spec hard drives can support up to 400GB. So I would like to suggest using 320 GB hard drives, and I see hard drives with this capacity still available on the market.
Aug 07, 2011 | Acer Aspire™ T180 PC Desktop
Acer aspire T180 wont start screen says no signal input computer is beeping cant tell beep code possibly 2 long beeps repeated or just one long beep repeated
Remove the side panel and remove the RAM.
Clean the RAM slot with dry brush or cloth.
Clean the RAM.
Fix the RAM back in the slot.
Close the cover and Start the PC
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 13, 2011 | Acer Aspire™ T180 PC Desktop
I want to upgrade the video card on my acer aspire t180 desktop
You will want to purchase a PCI-Express video card. Open up the side of the computer and place it in the appropriate spot to use the new video card. Check here for some possibilities.
Mar 13, 2011 | Acer Aspire™ T180 PC Desktop
Problem with acer aspire t180, SOUNDCARD don't work0.
If running XP:
Two things to check
Open Control Panel and select Sound and Audio. In the new window select the Audio tab and make sure your sound card is selected as the default playback device.
or
Open Computer management, click the plus sign by "Services and applications" and highlight "Services".
Scroll down to Windows audio and check that the service is started.
.Its also possible that a windows update caused this (sometimes malware or virus)
Hope this helps
Oct 16, 2009 | Acer Aspire™ T180 PC Desktop
T 180 desktop acer
Click on following link for audio driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-Audio-Driver-Download-37473.html
Click on following link for Ethernet driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-LAN-Driver-Download-37475.html
Regards,
Sandeep
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Acer aspire t180
plz check the hard disk and ram
Jul 20, 2008 | Acer Aspire™ T180 PC Desktop
Hard drive filling up
clear the temp folder and recycled bin
Apr 24, 2008 | Acer Aspire™ T180 PC Desktop
I have bought the acer aspire t180 ro1-b4
Hi hurontoolman, everything you need for Win XP is listed here.
http://support.acer-euro.com/drivers/desktop/aspire_t180.html
Acer Aspire T180 PC Desktop. You might want to add this link to you're Favorites.
If I can be of more service, just ask.
Mike
Apr 12, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
1,319 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
