Fit a door seal bush washing machine
How to fit door rubber
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
  • 1462 Answers
SOURCE: fitting door seal
this is general for fittying door boots.
on cabinet, door boot is usuallyn held by a wire ring tensioned by a small spring. prise it out with a screwdriver.
on tub, door boot is held usually by a giant hose clip for want of a better description. unscrew the tensioning screw and remove.
door boot will then pull off - just pull it off in one place then go round the circle.
to refit.
lubricate the groove in the door boot that fits on the tub with washing up liquid. insert groove on tub at any convenient place and force into position by running thumbs round it in opposite directions. this is a knack i have to say.
when on, replace the giant hose clip and tighten.
slip the outer part of the door boot on the cabinet - this is usually easy. replace the holding clip.
put onto rinse cycle to test for leaks
good luck
Posted on Jun 24, 2008
SOURCE: fixing new rubber door seal
have Maxx bosch machine trying to replace robber door seal. Can you advice how to do this as having difficulty with spring retainers
Posted on Aug 31, 2008
  • 1294 Answers
SOURCE: fitting of door seal on zanussi electrolux washing
Remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery.
To fit new seal
Lubricate the slot which fits over the tub with washing-up fluid - essential
Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange.When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands.
Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using in earnest. Use rinse to test as the water level is higher
Posted on Mar 12, 2009
emissionwiz
  • 76691 Answers
SOURCE: mold on the rubber seal of bosch washing machine
RUN A LOAD OF HOT WATER WITH 1 QUART OF WHITE VINEGAR, THAT WILL KILL THE MOLD, THEN WIP IT OFF THE SEAL
Posted on Aug 24, 2009
Zanussi fl 1084 washing machine door seal. How do I replace the rubber seal?
the seal comes in a shrunken size use a hair dryer to stretch it on to the door lip
Dec 03, 2013 | Washing Machines
Need a door seal for washing machine rubber door seal for bush MW-1260TVE
you need a part number or need to know where to buy the part
Feb 04, 2013 | Washing Machines
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Sep 28, 2007 | Washing Machines
How to replace rubber door seal
when you open the door you find a this wire clamp round the edge of the door seal, this just comes off with little force, this has to go back on obviously so don't bend it, the door seal just folds back on itself, the clamp on the drum end is often a large thin spring, and that also just pulls off, the seal then also comes away with a little pull, the new seal is fitted with the groove either side of the drum lip, then the spring is put back, take note how all is removed before working on it? the front of the seal is fitted then the wire, close the door to check a tight but easy fit, check for any leaks and correct fitting before leaving machine unattended any time, sound worse that what it actually is, if i have helped rate me,
Sep 16, 2007 | Bosch WFR 145 Front Load Washer
Washing Machines Logo
221 people viewed this question
Top Washing Machines Experts
