Question about Refrigerators
Vitapur water dispenser buzzing - Refrigerators
2 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: Recently our Vitapur water cooler
The problem is a comon one and simple. You just need to replace the themostat.
Good luck
Posted on Sep 07, 2010
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
Not sucking up water
the cap on the top of the water bottle at the elbow sucks air. Take off the plastic elbow and put a hose in place of the elbow clamp so no air and the water cool will pump water.
Mar 30, 2014 | Vitapur Energy Star Bottom Load Water...
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Vitapur water cooler troubleshooting
Mine was beeping after it overflowed. I could not figure out why, but my husband did. The beeping noise is a warning that your holding tank is too full. Just dispense some of the water and it will shut off.
Jun 15, 2012 | Refrigerators
Will not dispense water, but still makes ice
Sounds like either the water valve is bad or the line is plugged or frozen somewhere. To check the valve pull the water line off where the water feeds the reservoir have somebody try to dispense water you should have water coming out.If not try to dispense water again and listen for a slight buzzing noise if you hear the buzzing noise and you get no water the valve is bad.Always check the lines for freezing or restrictions before you replace the valve.
Jun 10, 2012 | Maytag MFD2561HE Stainless Steel Bottom...
Buzzing sound? 4yrs old already and started to have this sound. it's like the something is loose. I thought it was the ice maker, but not. what could that be? and is it safe to run it still??
When you use the water dispenser or the ice maker fills with water you can hear the water inlet valve solenoid buzz.
When you use the ice dispenser you can hear the solenoid buzz which opens the ice door.
Jul 09, 2010 | GE Profile PSW26P Stainless Steel Side by...
LOUD BUZZING SOUND WHEN DISPENSING WATER THRU THE DOOR
The water control valve on rear of refrigerator is weakening. That is typical sound for a coil that opens the side that dispenses water or ice tray refills to vibrate or buzz when weakening. If I had you r model number I could give you the part number. They are not expensive and easy to replace. Thanks, Sea Breeze
May 06, 2010 | Maytag Refrigerators
My water dispenser is running and will not stop.
Hi, There are 2 options that might be ha[[ening. Wither the water inlet valve has stuck open or the switch in the dispensor has gone bad.
Turn the water off to the inlet valve. Push the water dispenser button and see if you hear the inlet valve buzzing. Release the button and see if the valve stop buzzing. If the valve stops buzzing, the switch is ok. I hope this helps you. Please let me know if I can assist you later.
Vic
Jul 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
