Question about RCA TH1602 MP3 Player
I CAN'T HEAR ANYTHING! HELP!
The blue lights comes on, battery is charged, settings are set back to default, and I still cannot hear anything when I put the earbuds in! I don't know if its my earbuds or the mp3 player, because if I just stick the earbuds in my computer, I can hear music fine when it's playing from the internet and my windows media player. I don't get it...
That has happened to me before, what happened was where you input the earphone jack was broken, no matter how many different headphones i tried none worked. Now I understand this doesn't help, but it might save a lot of time.
Although one short short term thing i did find out though, is that if you push the headphone jack to the side, sometimes you will receive a little sound.
Tinker13
Posted on Jan 23, 2009
Acer aspire 2920 power light on fan spins then stops and wont boot
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 23, 2012 | Computers & Internet
My Acer 6800 on button light comes on, wont shut off! Wont boot up all the sudden!
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 02, 2012 | Acer Veriton 6800 PC Desktop
Jvc 56fn97 wont do anything but blink blue on power button
Reseat the lamp again, and make sure that the lamp door is completly closed and screwed shut. There are safety switches that keep the set from turning on if all is not secure. If this does not help, you either bought a defective lamp, or your ballast is the problem.
May 01, 2012 | JVC HD-56FN97 56" Television
Sony PCV RZ44G irresponsive
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Just because you see lights around the power button does not mean that the Power Supply is ok. I've seen many times when the Power Supply makes the light around the power button come on and makes the light on the motherboard come on, but it does not have enough power to make the Fan inside the power supply come on or anything else.
Apr 22, 2012 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
If the computers lights are just yellow what does that mean?
Just Yellow when? Tell us what happens time you put the power cord in and press the power button? Does it try to boot? Do the lights blink? Hear any beeps? Hear any fans? Does anything ever appear on the screen?
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge. Remove the Power Cord, Remove the Battery, Remove the Memory Cover on the bottom of the laptop and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 07, 2012 | Acer Aspire 5500 5570-2609 Laptop
I cant unmute my phone
i took out the battery and put it back in and i could hear again.
Jan 22, 2010 | Samsung Eternity Cell Phone
I cant hear any sound on my phone. only time i hear sound is when i get a call i hear the ringtont. but when i answer i can't hear anything. or even when i go to my sounds or ringtones and press play it...
First all I suggest you to format this phone as factory default, go in menu>>settings there is a reset factory default option select it; this will reset your phone to the default settings.
Make sure you loose all the data stored in phone.
Post further comments for more help.
Good Luck!!
Thanks
Jul 09, 2009 | LG VOYAGER VX10000 Cellular Phone
Speaker not working
More then likey you will have to perform a master reset to the device
Feb 02, 2009 | HTC G1
Red light stays on
First before a reset the set must turn on, if the set just sits there with the red LED on you have further problems, so does the set display anything?
Oct 08, 2007 | Mitsubishi WD-62525 62" Rear Projection...
RCA TH1602  MP3 Player Logo
95 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
