Question about Abit Digidice Barebone
Problem with crash and reboot
My system seems to be ok All startup is ok But After a while my system crash and reboot. I check my memory and no problem were found I just get a message that hardware problem have been detected and I should contact manufacturer company. I sent an email but no news ... I just found that my computes is more stable with less memory. So I use it will only 500M of ram instead of 1G. Any way it always crash and restart after 30mn. I wonder if I can troubleshooting my motherboard Thanks Config: CPU: Pentium 4 3G Memory: 1G Harddisk : 500G x2 Internal graphic chip set
  • Bertrand PIGEARD Jul 13, 2007
    I solve the probleme with a vacum cleaner and unplug plug the memory.
    After a good memory test (without any hardware trouble).
    My computer is now running well.
    70h without any crash and reboot.
    Thanks.
  • 84 Answers
What operating system are you using? Do you have adequate cooling in the case? It's possible it is over heating.
Posted on Jul 12, 2007
SOURCE:
I am using nComputing L230 Terminal but when I log in from the terminal, the windows and all related applications crash with exception code c0000005.
Uninstall your vSpace software, reboot, download and run their cleanup utility located at www.nc-eng.com/tools/ncuninstall.exe. Apply ALL MS service packs. Verify that no device drivers are missing or conflicting. Logon/logoff to the host and confirm proper functionality. Enable the Windows Startup/Recovery to capture a memory dump. This is done by the following steps: Right click on My Computer ' Properties ' Advanced Tab ' Startup and Recovery, Settings Button, Make sure Kernel Memory dump is selected. From there you can analyze the crash dump. Additionally, to help us, providing the complete hex code when the system crashes would help. Also, you never indicated what OS you're on or what version of vSapce you're using. All this is necessary to help you further.
May 18, 2011 | NComputing L230 Network Terminal
Why does blue screen appear suddenly sometimes interrupting my work and all of a sudden the computer restart by itself?
This sounds like a memory problem
try this: goto control panel, system, advanced, performance, advanced, virtual memory, settings
set start size and max size to same
mine is set at 2500
Apr 20, 2011 | Microsoft Computers & Internet
Hello my Acer Aspire M5640 just crashed it powers up but bios does not boot up can you help thanks I pulled memory out and cpu fan and power supply fan are on
If you have no 'BIOS' startup display, try:
  • Unplug the PC from the main AC power to force a hard reset. Reboot and test.
  • cleaning the memory board 'gold' contact with a white soft pencil eraser and swap them around if you have a couple. Reboot and test.
  • using a single memory board if you have more than one. Reboot and test for each memory board individually.
If you have 'BIOS' startup display, but fail to boot, also try:
  • Check and re-seat all external and internal cables (HDD, USB), and PCI cards (eg. Video)
  • Check Bios setting expecially for HDD
Hope it helps and good luck!
Jan 07, 2011 | Acer Computers & Internet
Dell D531 crashes on startup
This could be a software problem, or hardware. You need to determine which. I usually suggest troubleshooting memory first, but the D531 has memory under the keyboard, so in this case try booting from any bootable disk and see if the PC stays up. I like to use Ubuntu Live for my tests. You can get it here:
https://help.ubuntu.com/community/LiveCD
If that is stable, then your problem is probably in Windows and you will need to reload from disk. Make sure you backup any files first.
If your PC crashes off of the LiveCD, pull out half of your memory and try again. Next, try the other memory. The second stick of memory is under the keyboard. This assumes you have two sticks. Directions for removing memory can be found here.
Feb 15, 2010 | Dell Latitude D531 Laptop Motherboard ...
"Webcam is in use by another application."
in ue by another app is usually a driver conflict or a virus. if you have a 3n1 printer or a scanner unplug it and reboot the pc see if you get the same message. if not update the scanner or printer drivers. if the messgae return even after the reboot try a clean boot next.
To Boot Clean in Windows Vista Accessing the System Configuration Utility
1. Click Start and select Control Panel
2. Click System and Mantience
3. Click Administrative Tools
4. Double Click System Configuration
Configure Selective Startup options
1. On the General tab, choose Selective Startup
2. Uncheck Load Startup Items
3. Select the Services tab
4. Check Hide all Microsoft services
5. Click Disable all
6. Click on OK
7. Click Restart.
After performing the necessary steps, restore your system by doing the following:
4. Double click System Configuration
5. On the General tab, choose Normal Startup
6. Click Ok
7. Click Yes, when asked to restart your computer
To Boot Clean in Windows XP
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. On the General tab, choose Normal Startup
3. Click OK
4. Click YES, when asked to restart your computer
if the camera starts to work after doing this your looking at a virus have your pc cleaned by a pro.
Jul 20, 2009 | Logitech QuickCam Pro 9000 Web Cam
After a crash I had to remove the battery to get laptop rebooted but now it crashes with or without the battery.
this may be ram memory problem.remove your ram and clean it and restore back and change your hardisk data cable.ok..thank you.
Dec 16, 2008 | Computers & Internet
Clicking noise at startup, computer crashes/freezes
well man seems you lost files of system 32 folder. try formating then re installin ur OS
Dec 02, 2008 | HP Compaq Presario V2000 Notebook
I've Run Out Of Memory Without Adding Anything New To The System
When you deleted files, what you are freeing is hard disk space and not memory.
What I suspect is that at startup, your PC loads a number of programs that may or may not be essential for the system operation but nonetheless uses memory. This greatly reduces available/free memory and when you really want to run an application, the PC has no more memory to spare.
The easiest way I could think of to free up more memory is to streamline your startup applications. This could be done by running your System Configuration Utility (Start/Run, type "msconfig" less the quotes, Startup tab).Try to Disable All or uncheck all entries (except perhaps your antivirus and any application that you feel may be essential).
Additionally, you can increase your virtual memory. This could be done in your System Properties/Advanced tab/Performance Settings button/Performance Options Advanced tab/Virtual Memory Change button and select Custom Size. Numbers should roughly be equal to twice your real memory (say onboard is 512, then virtual = 1024). You need to click on the Set button, OK,OK,OK and reboot.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Dell Inspiron B130 Notebook
Turning on, crashing ans screen
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372718&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035372&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00037733&lc=en&cc=us&dlc=&product=435618&rule=44570&lang=
Jan 09, 2008 | HP Pavilion dv1000 Notebook
Abit Digidice Barebone Logo
75 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Bart Fonteyne
Dapid Candra
Dapid Candra
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
