The machine fills with water but the drum wont turn. the machine drains the water until the next cycle, but the drum still wont turn
    Sergeant:
  • 291 Answers
Tony could you give me a little more info? Is this a machine you just got or one that's been running just fine till now? Is it a top loading machine or a front loading machine? Because if this is a top loading GE for example i'd say, see if the agitator spins freely in both directions if it is and if it does i'd give you some instructions on an easy repair. However if you said it's a whirlpool top loader i could probably give you a link to a youtube vid that'll show you step by step how to fix it. Etc. Etc. Thanks.
Posted on Jan 13, 2013
  • 6 more comments
  • tony mendoza Jan 13, 2013
    The ajitator spins freely to the right but not to the left, althogh the drum does. We just had the pump replaced and hadnt used
    it is a top load. ajitator spins freely to the right but not to the left.
  • B.H. Countryman Jan 13, 2013
    G.E.? Whiirlpool?
    its a GE. do u think it might be the lid magnet
    You can do a fairly reliable test of the lid switch just by opening and closing the lid. Should hear a distinct click when lid first opens and a distinct click just before it closes.
    Is there a panel on the front of the machine that looks removable? It might have visible screws at the bottom, but it may not.
    No. it doesnt look removable. but there is no distinct click upon opening or closing the
    Then it is probably the switch, assuming the magnet is still attached to the lid.
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
SOURCE: Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Posted on Sep 24, 2008
SOURCE: Indesit wd125 drum wont turn
check your pump it may not be working
Posted on Dec 18, 2008
SOURCE: No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Posted on Jun 02, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
Samsung wf7600naw wont spin
has all the water drained out of the drum as the next cycle will not start until then, make Shure that the outlet water pipe is not blocked just a little preventing the water from empting properly eric
Dec 21, 2017 | Samsung Washing Machines
My washing machine wont fill up with water, what would the problem be, ive cleaned the hose at both ends so its not blocked?
usually the hot and cold water solenoid fail stopping water to flow
replaceable part
location
in where the hoses attach to the washing machine
May 09, 2016 | Washing Machines
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
I have a candy AQ 1200, it fills with water then drum turns and s
sounds like m/c is waiting to heat up water but heating element is not working or timer switch not going on to next cycle.
Aug 21, 2009 | Candy Washing Machines
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Washer constantly draining after first cycle
For the machine to keep filling it would indicate that there is a siphoning problem. Check the outlet hose is not running along the ground, it has to rise up then loop back down or the water will just run straight down the drain. If the problem only happens after the first pump out it would indicate the end of the outlet hose is lower than the drum or there is no air break around the outlet hose. (The stand pipe should be larger in diameter than the hose from the machine).
http://selfix-uk.co.uk/under%20sink%20plumbing.html
May 01, 2017 | GE Spacemaker WSLP1100D Top Load Washer
Dec 18, 2008 | Indesit W 123 Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
