Question about AR Blue Clean AR390 - Pressure Washer
Chem injection system
Plugged
How do I time a 185 Yamaha exciter 1981?
Hi, Lou your carb is the issue and may need to use Berryman Chem Dip to remove hidden contamination and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Carb Cleaning Pinesol vs Berryman Chem Dip
http://www.mikuni.com/pdf/vmmanual.pdf
Yamaha Sr185 1981 Usa parts lists
http://www.manualslib.com/manual/882832/Yamaha-Sr125-1997.html
Aug 12, 2016 | Yamaha Motorcycles
Do you cut the injection end to the length required
Yes, The injector tip cut on a diagonal to contact the center of the pipe water stream.
Jul 09, 2014 | Pulsafeeder J41694 back check injection...
Floating ball stuck in Chem-tech 100
I Googled it and there are several places, one thing I would suggest would be once you get the part numbers you need check Amazon.com and Ebay for competitive pricing chem tech series 100 parts Google Search
Apr 19, 2014 | Pulsafeeder Pump Repair Kit Chem-Tech
1994 CHEVROLET C1500 PICKUP 4.3L V6 vortek cranks no start backfiring thru the Throttle body fuel injection system. The Distributor has a small hairline crack under the reluctor wheel could this be the...
100 psi per cylinder is way too low--should be in the vicinity of 150-165 per cylinder
back firing indicates wrong firing order and as you have replaced the plugs etc check that you have the leads on the correct plugs in the correct order
the timing for the engine should be around the 10 degree btdc and not tdc
Mar 23, 2017 | Cars & Trucks
Is there not a radiator cap on a 1999 silverado? want to flush sysyem but do you refill through resavoir?
If you don't see a cap, you don't have one. If you are flushing in hopes of correcting an overheating problem, be aware that if the radiator is partially obstructed, the flush chems sold today are too mild to actually do much. The better chems were all banned by the epa.
If you are just doing routine maintenance, easiest method of draining is to remove the lower hose at the radiator, let the system drain, put the hose back on, fill with water and any chems you want to use, run it as per instructions, drain again, fill with more water and repeat with water at least twice before draining and filling with new antifreeze.(do all flushing with heater on full heat) Keep the cap off while doing this so you don't build up pressure and be careful draining hot water. Even though they are mild for the job, chems can still irritate your skin so be careful. When filling for the final time, make sure the system is full and the thermostat has opened before closing it up. Always check everything over for leaks.Any other questions? Just ask!!
May 30, 2011 | 1999 Chevrolet Silverado 1500
2000 neon 249948 mile loosing fuel enco and power
for fuel....it could be a dirty or clogged air filter or emission system not working properly or fuel injection system not functioning properly...
for loss of power......worn camshaft lobes, faulty spark plug wires or coil, fuel injection system, air filter plugged, low compression or uneven cylinders....
Apr 29, 2011 | 2000 Dodge Neon
Okay its like when i press the gas it stalls or when im at a light my car would sputter and then slowly die out and cutt off my alternator is good i tested it at auto zone and i replaced my battery what...
That car may have a carburetor.....that is...pre- fuel injection. Have it checked for adjustment, linkage problems, accelerator pump failure....or may need to be rebuilt. If it has been sitting for a long time, blow it out with some chem-tool, then take it for a ride on the highway and blow the cobwebs out of it. USE COMMON SENSE....wear eye protection when messing with chem-tool or simular. Have a fire extinguisher handy. Replace the air breather back on the carburetor correctly....because, if it backfires while driving it, it could catch fire. ( ever see a car on the side of the highway...on Fire...?) this is why....!!
Theroadisalover
Jan 06, 2011 | 1986 Chevrolet Caprice
Improving mileage
i use b12 chem tool in my tank every other fill up very strong solution and it removes carbon and other deposits like nothing engine builders use this for soaking parts like valves and carburetors to remove deposits i would say it is your best friend for improving gas mileage and restoring your engine and fuel system to like new condition, please pick up a can for your fuel tank and tell me what you think it comes in a spray and an additive you want the fuel system additive please rate-jeff ps i dont work for or sell B12 Chem Tool i speak from experiance
Jul 06, 2008 | 1995 Plymouth Voyager
AR Blue Clean AR390 - Pressure Washer Logo
Top AR Blue Clean Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an AR Blue Clean Garden Expert? Answer questions, earn points and help others
