Question about Dynex Televison & Video
How to hook up sound bar to dynex tv - Dynex Televison & Video
4 Suggested Answers
SOURCE: dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Posted on Dec 27, 2011
spr1949
  • 1182 Answers
SOURCE: How to hook up a sound bar to a Apex 32in tv # Ld 3288 t
Please follow guidelines in operation manuals of both.
Posted on Jul 25, 2012
  • 214 Answers
SOURCE: hook up sound bar to zenith plasma tv
If the sound bar has the red and white cable then yes you can use those. Make sure in your settings for the TV you have it set for an external audio source. Since you don't want to use the built in speakers. Probably best to get a tuner if using multiple speakers and a sub.
Posted on Dec 29, 2012
My son's Dynex TV has no sound except when he plugs in his xbox. What do I do?
If the TV has sound using an Xbox, then the problem is not with the TV, otherwise you would have no sound no matter what you hooked up to the TV. You may have to adjust the TV menu controls that involve receiving a TV signal that provides both sound and picture.
Nov 17, 2014 | Dynex Televison & Video
We are trying to hook up a VIZIO sound bar model#S3820w-Co to our Vizio TV we also have Directv and a dvd player hook to this tv which wire do we hook from sound bar to Tv
If the TV and sound bar have an optical connector, then get the optical cable to connect the two. If not then use the audio out jacks on the TV and don't forget to change the audio set up to switch the sound to the sound bar.
Oct 29, 2014 | Televison & Video
How do I connect wireless headphones to a Dynex 42"TV model DX-42E250A12?
Check this link for a user manual
http://www.dynexproducts.com/cms/documents/Manuals/DX-42E250A12_11-0618_MAN_V1_EN_Final%20lr.pdf
Sep 07, 2014 | Dynex Televison & Video
How to connect soundbar
You Can Use RCA Cables, Hdmi Cable Or Optical Cable Out From Your TV To The Sound Bar. Look At Your "Out" Choices From TV And MatchThe Same Style Of Connection On Your "IN" To The Sound Bar.
Jul 21, 2014 | iLive Audio Players & Recorders
Where are the audio out jacks?
for the Dynex DX-L26-10A the audio out jacks are located to the left of the RF connector and just above the audio input connectors.
PDF for the DX-L26-10A
Dec 15, 2013 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Just bought a G-Sonic 32 inch sound bar came home hooks it up to my Vizio 42 inch tv no sound with bar??? RCA on TV and bar a PC and plug in no sound ?
I had the same problem, no sound from tv to the sound bar. I hooked up the output for sound from the sound source, your cable tv box or satellite receiver and ran it to the sound bar, and then received sound.
Nov 29, 2013 | Televison & Video
My tv is a dynex and everything is hooked up to the cable box but my tv doesn't make any sounds. I turned all the volumes up.
Check in the tv\'s menu, there should be an option for audio. In that section there should also be an option that says internal speakers or somthing like that. Make sure its turned on.
Jan 06, 2013 | Computers & Internet
The tv is hooked up to our dvd player. We get a
hi,
Plz see to it that if all of jacks of dvd player are correctly and firmly inserted into the respectively coloured mating jacks of ur TV. If u still dont get a sound, it will be better if u purchase a new set of jacks.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
I hooked my dvd player up to my tv. There is no sound
You have a great night too.
Happy DVD movies. :)
May 25, 2009 | Dynex DX-LCD37 TV
Televison & Video Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
