Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigerator runs hot.
We have a side by side refrigerator. The front of the panel where the doors are closed feels warm to the touch. Does it need to be replaced?
  • bailorgb Jan 23, 2009
    Thanks, I'll tr it tonight!!
  • 3 Answers
Replacement is probably not necesarry. a good cleaning is usually the problem if you pull it out and vacume all the parts under it and in front make sure the condensor and coils etc. are not built up with dust. this is usually the problem.
Posted on Jan 23, 2009
2 Suggested Answers
  • 89 Answers
SOURCE: Front center panel where doors meet to close are
yes they have heaters in them to help reduce moisture on the ref you can ussually turn them off by turning the energy saver feature on but this may cause moisture to build up on the exterior part and the inside of th ref
Posted on Sep 06, 2009
Testimonial: "Thjanks"
(1.Contents are no longer getting cold. Thermometer jumps to the upper sixties and everything feels close to warm. (2.Inner edge of doors are very hot to the touch. (3. Prior to this, it would make an...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 22, 2010 | Refrigerators
Very hot to touch between fridge and freezer on front panel
on front panel around the door where the door seal goes up against is this what is hot check the compressor fan in the back of the machine when it doesnt run or is unoperational then the sides around the door get hot you might have to replace the compressor fan
Aug 12, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
The front of our refrigerator where the doors rest when closed is hot to the touch. Also, it seems to run more frequently. What could this mean?
the area the door rests on is normal to feel warm. it has a heater to keep it from getting condensation around the doors. Some models have a switch on the inside to turn this off. It usually says something like energy saver. As far as it running more frequently, Could be several things that would be hard to diagnose without seeing it.
Jun 18, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Front center panel where doors meet to close are very warm/hot to the touch. Is this normal for this refrigerator?
Sep 06, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The door seal contact surface is hot to the touch.
ther so pose to be a switc if none that for hummit
Jan 17, 2009 | Kenmore 53082 / 53084 Side by Side...
Mullion between freezer and refrigerator is extremely hot.
They rarely use 'heaters' anymore. If there is a heater there will be somthing like a 'energy saver' option to turn it off. More likely it is a mullion loop that is part of the sealed system tubing. The harder the frige works the hotter that area will be. So if the inside temp rises so will the temperature of the mullion. Start by checking your frige and freezer temperatures with a thermometer. The freezer should be between 5-10 deg ABOVE zero and the frige should be about 35 or 36 deg. Also check that the condenser is not dirty. The condenser is the coils that are usually underneath the frige. They should be cleaned at least annually. Also while you're under there make sure the condenser fan is running. You should feel a little air movement and possibly hear it running from the front under the doors. If it's not running you'll need to find out why, but would usually be a problem with the motor. Also there was a carboard panel on the back at the bottom of the frige from the factory, that panel HAS to be in place to direct air across the condenser and not back behind the frige.
Jul 19, 2008 | Samsung RS2630SH Side by Side Refrigerator
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Loud Humming and Hot Front Panel
DONT TOUCH ANYTHING. IF IT IS COOLING CORRECTLY LEAVE IT. LOUD HUMMING IS COMMON ON SOME COMPRESSORS.(ANNOYING I KNOW).THE HEATING ON THE FRONT IS NORMAL AS IT IS THE MULLON HEATERS WHICH RUN THROUGH THE FRAME. IF THAT AREA WERE COLD, CONDENSATION WOULD OCCUR AND WOULD DRIP CONTINUOUSLY.
May 31, 2007 | Whirlpool 21.7 cu. ft. Side-by-Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
96 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
