Question about Kitchen Appliances - Others
Manual castel garden R 484 TR - Kitchen Appliances - Others
3 Suggested Answers
  • 252 Answers
SOURCE: I need a diagram for
pauly46_0.gifpauly46_1.gif hi there winger1886
pauly46 here
with 20/122 the blade timming must with one blade vertical and one blade horizontal
doesnt matter which one but as long as there is 90 degrees between blade as the rotate
in the picture the r/h blade rotates anticlockwise and the l/h blade rotates clockwise
the picture for belt / blade timming is straight forward - loosen tensioner rod and back it off completely , loosen 2 x bolts under the two toothed pulleys and remove the 2 belt guide/ stoppers from the l/h side - place both blades in the rqd position ( you may need someone to hold other blade in rqd position - fit the belt onto pulleys as in the diagram- continually check while fitting that timming has not moved from where you placed them ( they have to be 90 degrees from each other ) and then tighten the tensioner rod to hold position - rotate by hand recheck timming - if good loosly fit guide the 2 guide stoppers to l/h side and place 3.5 kg of tension at the middle point of the longest run of timmed belt ( belt should only deflect 10 mm with 3.5 kg of tension )
once tensioned tighten the 2 bolts under the toothed pulleys and tighten loc nut on adjuster
tighten the 2 stopper / guide nuts
in the picture the left hand blade is a l/h thread undo it right and tighten it left
the blade on the right is a normal thread left loose - righty -tighty
cheers hope it helps
Posted on May 23, 2011
gopakumarg43
  • 75304 Answers
SOURCE: is there an owners manual for a castelgarden TC12.5/102 sit on mower
www.retrevo.com/ Try this site to download it. Electro help
Posted on Oct 25, 2014
Testimonial: "Thanks or the tip but it was not available on the site"
I have a castel garden xe80 rideon wont start the box the pcb held in melted the pcb board warm no fuses blown no sign of shorted wires
If the pcb got hot enough to melt it's case then the pcb is bad. You cannot visually inspect most electronic components for damage.
Jul 17, 2016 | Cars & Trucks
My mower starts easily, has NO motion forwards or reverse. s a drive belt slipping or what?
unset the brake push pedal all the way down and release it
Apr 10, 2015 | Garden
Has 484 international tractor got a diesel pump
If it is a diesel then find the pipes that got to the head and trace them back to the pump. It normally sits next to the block and is connected through the timing cover back plate to run from gears on the crank shaft
Jun 05, 2013 | Garden
I lost my manual and I forgot how to program #s on my phone
here's a manual you can download: http://www.barclayent.com/manuals/Southwestern%20Bell%20FT-484.pdf
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial----- ---if I help you please help me---
Thank you for choosing fixya
Roger
Sep 03, 2011 | Southwestern Bell FT-484 Corded Phone
Replacement blade for castelgarden C390 lawnmower
What Geographic location please?
UK:
http://www.ebay.co.uk/itm/Mountfield-Castel-Garden-EL390-R-C390-K390-Mower-blade-/280561700508
The blades on most sites are listed under Mountfield / Castel / Lawn King
There are 41cm and 37cm blades listed as fitting this mower. Seems odd that there is a 4 cm difference for the same mower.
As best I can tell this takes a 15 inch blade PN: 81004117/1 (
http://www.gardenhirespares.co.uk/product_list/81 See 15 inch blade
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | OEM Replacement Parts Lawn Mower Blade...
Lawn Mower Repair
if the mower is a castel garden the blade boss above the blade may be sheared and needs replacing otherwise top cover over deck has to be taken off to adjust timming belt
Oct 19, 2008 | Garden
Kitchen Appliances - Others Logo
254 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
