Question about Memorex MVD2022 DVD Player
No disk keeps popping up - Memorex MVD2022 DVD Player
  • 6,784 Answers
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
(You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more).
Posted on Jul 28, 2009
Stop a rear caliper from popping open and leaking
have you replaced the disk? if they have run out,"warpped" tehy will cause problems. spin rotar an see it there is alot of run out.
Feb 01, 2015 | Dodge 1997 Ram 1500
Wont load Disks error c13
The error statement indicates the disc cannot be read by the recorder, it may be dirty or damaged or recorded in an extended format which this deck cannot read.
Feb 11, 2014 | Sony MDS-JE480 Mini Disc Player
My disk c is full
Run Disk CleanUp.
Start, All Programs, Accessories, System Tools, Disk Cleanup
- Select the Drive you want to clean up (C:), then check off Temp internet files, temporary files, setup log files, and recycle bin.
If your still receiving that message after running disk cleanup, You might need to go into uninstall some applications.
Jan 11, 2013 | E-Machines eMachines Desktop PC
My system is not reading the disks
have you tried a disk cleaner as this happends to mine now again pop a disk cleaner in and ok
Dec 12, 2011 | Nintendo Wii Console
Disk stuck
Look in the front of the DVD slot, you will see a small "Hole" using a paper clip or other piece of Straight stiff wire, insert the wire into the hole, keep pressing in until you hear/feel a "Click" keep on pressing in gently and the DVD will pop out.
Feb 23, 2010 | Nintendo Wii Console
A Disk read error occured PressCtrl+Alt+Del to restart.
If you are getting a disk read error, you will need to use a program like spinrite to fix it or you will need to replace the hard drive.
This is one error you don't want to see. It means your hard drive is failing.
You will not be able to do a system restore as long as you get this error.
Sep 22, 2009 | Computers & Internet
HP Product Assistant disk
go online to Hp webpage, download the driver and install it. it will fix your problem.
Regards
Aug 02, 2009 | HP Deskjet 6940 InkJet Printer
Main menu inviting to take a tour on how to adjust the monitor keeps popping up uninvited.
Your screen settings are not optimized for that monitor, most Gateways (to h*&%) come with a drivers disks for the monitors put that in and run setup for the monitor.
May 02, 2009 | Computers & Internet
The dvd keeps popping back out
Try a disk player cleaner , it a disk with little brushes on it, most places have them, walmart ,radio shack, best buy,if you hurry circuit city,kmart etc,.
Jan 25, 2009 | Audio Players & Recorders
Pinnacle studio
CHECK IF THE DISK YOU ARE USING IS BIG ENOUGH FOR THE MOVIE YOU ARE MAKING.
MAKE SURE THAT THE DISK IS NOT A USED ONE TRY A REWRITABLE ONE FIRST.
Sep 08, 2007 | Pinnacle PCTV 110i (210100458) Video...
Memorex MVD2022 DVD Player Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
