Question about Hotpoint Washing Machines
REPAIR MANUAL FOR HOTPOINT WASHER VBSR3100
WILL SPIN BUT NOT AGGITATE
SolutionGuy
  • 331 Answers
SOURCE: washer wont spin, dont know how to open top of
Hi Mr_C,
Front panel access is easy with just a putty knife, a flashlight and a flat screwdriver... but I'd almost wager that the belt is fine and the motor pulley/clutch is trashed.
Here's how you do it... {{{UNPLUG THE WASHER}}}
Shine your flashlight into the gap between the top and front panels. You'll see a couple of clips in there about 3" in from either side. Use your putty knife to slide into the gap and depress these clips while at the same time pulling the front panel toward you. (You may have to POP the end of the putty knife a time or four, those clips don't wanna let go easy) Do this one side at a time. Now the front panel will rotate out about 45 degrees and lift off of the 2 clips at the bottom. Set the front panel aside.
This gives you access to the cabinet where you can use your flashlight to inspect it. If it turns out that you are right and the belt is thrashed, Great! It's a part number WH1X2026 and can be purchased for about $10.00. If it's what I suspect (the pulley/clutch on the bottom of the motor) that's a different story. It's a part number WH20X10019 and retails for about $170.00 (you gotta replace the whole motor, not just the pulley/clutch).
If I were running this service call and found it to be the motor? I'd recommend not repairing it because you'd have more invested in the repair than what the machine is actually worth. "Upside Down" in car-speak.
I really hope this helps you,
SG
Posted on Mar 25, 2009
  • 686 Answers
SOURCE: Washer won't aggitate or spin.
your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Posted on Apr 06, 2009
SOURCE: Washer fills and drains but won't aggitate or spin
Since the washer is less than an year old it must be under a warranty.Try contacting the customer care and get it replaced.
Generally for such a problem,the following checks need to be done.
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In your case I would advice to get your machine replaced with a new one.Good luck,Please do rate the solution if accepted.
Posted on Apr 10, 2009
  • 32 Answers
SOURCE: Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
Posted on May 24, 2009
  • 77 Answers
SOURCE: My washer won't spin or aggitate. I have a GE
Check the belt and clutch in the front under the lid run a butter knife under the lid and pop the front off and take a look.Have a great Thanksgiving.
Posted on Nov 25, 2009
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
I have a GE washer (WBB4500G2WW) - wont aggitate or spin
The BELT... Part number wh01x10302
30% of the time is the issue here:
http://www.appliancepartspros.com/ge-belt-wh01x10302-ap3968432.html
Have a look at appliance-parts-pros (video guide)
http://www.appliancepartspros.com/repair-help/general-electric-washer-wbb4500g2ww-repair/wbb4500g2ww-pumps-but-will-not-spin.html
May require a specialty tool to mount the belt
(depicted in VIDEO... Sold on site): view here:
http://www.appliancepartspros.com/ge-service-kit-belt-wx05x20641-ap5957260.html
((not entirely convinced the tool is critical but the
Also check prices on eBay (top seller, free shipping
WH01X10302 AP3968432 1264395 PS1482278 WH01X10353 Washer Drive Belt eBay
Hope this holds off trashing your three year old washer...
Carnac the Magnificent
Jan 15, 2018 | Whirlpool Washing Machines
Washer doesn't spin GE WCSR2090
does it aggitate??
the safety button is most likely broken, you can see the small hole where the figer pushes down to stop the spin cycle, if the washer does not aggitate, then most likely it the safety switch.
get it replace, or bypass(not adviseable) but only when you need it,
Water that doesnt move tend to get stinky fast!
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Oct 29, 2010 | Washing Machines
You start the washer and the water will fill up to where it is suppose to but will not start to aggitate.The water will drain but the drum won't spin,than it will fill up again and it won't agitate...
Your drain hose is maybe too low and therefore gravity is draining out the washer OR the drain hose is too tight in the drain and a siphoning effect is happening.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 22, 2010 | Hotpoint Washing Machines
VBSR3100, fills and agitates but nothing else works
CHECK OUT THE DRAIN MOTOR PUMP , Its where the drain hose is connected to , youll see like a small fan , it could be clogged and needs to be removed for cleaning, hope it helps , AJ
Jul 24, 2010 | Hotpoint VBSR3100D Top Load Washer
Will not aggitate or spin,
lid switch remove back panel switch on rt rear corner could have microswitch or fuse depends on mdl #
Feb 04, 2010 | Maytag Washing Machines
Nov 25, 2009 | General Electric WHDSR209DWW Top Load...
Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Hotpoint VBXR1090 Washer
sounds like your brushes need replaced or your motor would try the brushes first
Jan 08, 2008 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
73 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
