Question about MA Audio HK4000D Car Audio Amplifier
Trying to power a amp with 16 volts. possible?
I am trying to install a amp and sub in a 48 volt golf cart. which has 6/ 8 volt batteries. will my amp run if i put two batteries in a series and create 16 volts?
  • 2 more comments
  • johnjmunger Jan 23, 2009
    do you know if they make a smaller amp 400-600 watts that will handle 16 volts . we are working with a very limited space and cannot fit another battery.thanks for the help
  • johnjmunger Jan 24, 2009
    hello.
    wow that is awesome info. this will definately work then we are looking at using a sony sub to start just in case of destruction we wont be out alot of money. but rockford fossgate has always been my sub of choice. i still have a set of 10" in my truck that have out lasted 4 trucks. so i am a fan of their products
  • krishna May 06, 2013
    can all amps work at 16 volt or it wil blow
    i made a power supply and it delivers 16 volts and 25 amps.how many watts amplifier can i connec5t to this powersupply
  • 100 Answers
Pick any two batteries that have one wire connecting them together, connect your ground to the neg on one battery and your positive on positive post on the other battery, that should give you 16 volts. Also fuse your wiring on both sides just in case.
Posted on Nov 08, 2009
  • 15,935 Answers
Golf carts do not have a charging system. If you are going to use battery power only, why not just add (1) 12V car battery instead of (2) 8V??
MA Audio runs (ran) their bench tests @ 17V. All the power ratings advertized are at 17V.
The power supply for the hk4000D is unregulated. So the more voltage = more power.. 8V-16VDC.
  • RMS Power @ 14.4V
    • 1800W x 1 @ 4 Ohm
    • 3600W x 1 @ 2 Ohm
  • RMS Power @ 17.0V
    • 2000W @ 4 Ohm
    • 4000W @ 2 Ohm
    More input voltage means the amplifier will have to work less hard to make power.
    Don't expect the amplifier to work for very long however. the current drain on a class D amplifier is huge. There are no on-board fuses protecting the power supplies, so be sure to have at lease a 150A power line fuse.
    With 150A current draw - even with the amplifier at 1/2 gain - expect to get 10.6 minutes of listening time from your 16 volts before recharging - also note, the amplifier MUST see 8V to turn on, there is a built-in voltage sensor that will shut down the amplifier if voltage is too low.
  • Posted on Jan 23, 2009
    • blueextc3221
      blueextc3221 Jan 24, 2009
      Ma audio makes many small amplifiers. In the HK series, the HK1998 is 12"x2"x12" (just a tad smaller)
      But the HK is their HARD Kore line - meant for pure power!
      Are you stuck on MA Audio? or are there other brands you would put in?
      What is the subwoofer you are using?
      You need an amplifier that has an UNRegulated power supply. So the 18V it can handle. US Amps older USA series with anodized aluminum chassis are popular in golfcarts. Something else you may want to consider is a MARINE amplifier to keep it safe from the rain if it is going to be outside. Thay are made with stainless steel fittings/terminals, and are sealed to resist water!
      Let me know!!
      Here is a pic of an older USAmps USA-200 (smallest). I remember they are available in blue, red, green, tiedye, and purple.
    I have a golf cart with six - 6 volt batteries. It has no lights and I would like to know if I can install a 6 - volt light utilizing this 6 - volt system.
    sure can just make sure your hot wire is fused at the source and id suggest using led lighting to save power draw.
    Nov 21, 2017 | Golf
    Club car DS golf cart
    Check all your batteries with a meter you may have one with a bade cell.
    Jun 07, 2016 | Golf
    My cart has 6 8volt batteries that are dead my manual shows 4 12 volt batteries should I replace the 6 8 volt with 4 12 volt batteries
    make sure that they are in fact 8 volt batteries
    You can replace them with 6 by 12 volt batteries as the end voltage (48 volts ) is the same
    Mar 22, 2016 | Golf
    Can i use 3 12volt batteries in a golf cart instead of 6 6volt batteries
    Yes you can but the down side is that the total amp hour rating from 3 x 12 volt batteries may be a lot less than the amp hour rating from 6 x 8 volt batteries. This means you will run out of battery power a lot sooner.
    Mar 15, 2012 | Cars & Trucks
    Batteries run out of power too quick, what is my problem? ezgo golf cart electric. What would the total voltage be with 6 batteries?
    The voltage should be above 37 volts if you have 6 volt batteries. This must be measured under load. A simple voltage check is useless. If the batteries are over 6 years old, they are probably in need of replacement.
    Sep 27, 2009 | Garmin Golf Walking Cart Mount For ...
    Want to connect electric lights to ez-go electric golf cart. It is a six battery system and I want to simply add a front light and rear red light.
    You said you have 6 batteries. Are they 6 volt or 8 volt? Hint-- 6 volt has three holes in the top and an 8 volt has 4 holes on top of the battery. Battery manufacturers recommend the use of a voltage reducer wired to the whole bank. This take the 36 or 48 volts down to 12 volts and is regulated. this is recommended so as not to stress just 2 batteries. If you have 6 volt batteries, you can use any 2 that are wired in series.
    Sep 21, 2009 | Garmin Walking Cart Mount For Golflogix...
    Wiring diagram
    dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
    good luck
    Wiring diagram
    Jul 24, 2008 | Car Audio & Video
    Radio installation in a golf cart
    Each battery is 6 volts. You would have to connect to the 1st Battery 12 volts posiltive {+} side and the 3rd battery negative side[-]. Run the positive lead thru an inline 10 amp fuse , then to the radio.
    Jul 22, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
    Open Questions:
    MA Audio HK4000D Car Audio Amplifier Logo
    668 people viewed this question
    Top MA Audio Car Audio & Video Experts
    Mark Skinner
    jamie suver
    Level 1 Expert
    Robert Rankin
    Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
