Question about Dehumidifiers
Noisey Overheating Dehumidifier
Hello! my dehumidifier is overheating and cutting less than 3min.it's an enerystar brand with the tray you empty at the bottom. It's never been off for the 1 year and 3months that I lived here only when it automatically cuts off too be empty and clean. Do you have an idea what the proble could be and what you would recommend? because it belongs to my landlord...thank you!
  • 883 Answers
SOURCE: Really thick ice on back of dehumidifier
It is now frozen because the humidistat, which controls the on/off cycle, is starting to age and forgetting to turn off the dehumidifier. Try removing the humidistat and, using compressed air, blow it out thoroughly of any dust. Then spray the rotary control area, including electrical parts, with WD-40. Then, blow dry again with the compressor and try again.
Posted on Jun 24, 2007
SOURCE: Overheating
Same problem, I cleaned the filter etc. seems to run ok, but gets very hot on the top and sometimes smells hot. No signs of burning etc.
Posted on Oct 15, 2008
SOURCE: Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Posted on Jul 20, 2009
  • 117 Answers
SOURCE: Danby Dehumidifier DDR557HE has never dehumidified
either lacks coolant or compressor bad
Posted on Jan 05, 2010
Testimonial: "Thank you, I didn't even know a dehumidifier had coolant. "
heatman101
  • 43501 Answers
SOURCE: whirlpool dehumidifier makes a lot of noise when
When the compressors start to go bad they often start to get very loud also...the cost to replace the compressor will probably be more then a new unit...
Also check out this tip about dehumidifier problems...
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
Posted on May 04, 2010
Testimonial: "thank you for your help .it has been noisey for too long a time to be the compressor but you are probably correct on this..it started to make noise after the very first year of buying it. We did buy it in 2006.."
HE70ER-L Are there any recalls on this Haier Dehumidifier model?
Results
Dehumidifier Recalls - ConsumerAffairs.com
https://www.consumeraffairs.com/dehumidifier-recalls
  1. Cached
The recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission (CPSC). December 30, 2009 LG Electronics is recalling about 98,000 portable dehumidifiers. The power connector for the dehumidifiers compressor can short circuit, posing fire and burn hazards to consumers.
Humidifiers & Dehumidifiers Recall List by WeMakeItSafer
wemakeitsafer.com > ... > Home & Garden > Temperature & Humidity Control
  1. Cached
  2. Similar
Danby, De'Longhi, Fedders, Fellini, Frigidaire, Gree, Kenmore, Norpole, Premiere, Seabreeze, SoleusAir and SuperClima Dehumidifiers. A recall was issued on 2013-09-12 due to a potential fire and burn hazard.
Dehumidifier Recall: How to Find Out if it Affects You
learn.compactappliance.com > A/C & Heating
  1. Cached
  2. Similar
Jun 12, 2014 - How to Find Out if Your Dehumidifier Was Recalled. ... Many popular brands known for having high quality dehumidifiers such as Danby, Frigidaire, and Soleus had models affected by this recall. ... Brands have taken different approaches to how they have responded to the Gree dehumidifier ...
Dehumidifiers recalled after overheating, fires - USA Today
www.usatoday.com/story/money/business/2014/.../dehumidifiers-recalled.../9145635/
  1. Cached
  2. Similar
May 15, 2014 - Appliance manufacturer Gree has issued another recall for a line of its ... .cpsc.gov/en/Recalls/2014/Gree-Reannounces-Dehumidifier-Recall.
Public Notices ' Haier America
https://www.haieramerica.com/public-notices
  1. Cached
Product Recalls. The latest public notices can be found here. Recall Date. Haier America Expands Recall of Chest Freezers Due to Fire Hazard, Sunday, May 12 ...
Nov 07, 2016 | Haier Dehumidifiers
The float is broken in our dehumidifier, is it repairable?
Is the float in the empty or full position?? If it is in the empty position, and the unit will run normally, then yes you can. The water will divert from the evap tray right into the hose. If it is stuck in the full position, and wont run because it thinks it's full, you will have to find a way to put and hold it in the empty position.
Nov 10, 2013 | Danby DDR600R Silhouette Dehumidifier
Is there a recall on this product? My compressor and fan run but no water is collected. I know other Amana dehumidifiers were recalled for fire risk due to compressor overheating so I took cover off and...
Your description indicates a loss of refrigerant in the dehumidifier. The metal heat exchanger above the water collector should become cold when the compressor is running - if it does not, your dehumidifier likely has lost it's refrigerant charge. You will have to take it to a certified (refrigerant handling) technician to repair. It may make more sense to replace with a new dehumidifier.
Check the CPSC website for dehumidifier recalls. they will have details of the brands/models/serial numbers of recalled units.
Oct 23, 2013 | Amana D545M Dehumidifier
Has there been a recall on this product? My compressor seems to run but no water is collected. I took the back cover off and the compressor is extremely hot and I know that other Amana dehumidifiers were...
Clean cooling coils. in the last week or so my dehumidifer in the basement seems less productive in collecting water, i have two down there and the other works - i have to empty it often, thats how i...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Sep 18, 2011 | Maytag M7DH45B2A Dehumidifier
Whirlpool dehumidifier makes a lot of noise when running and vibrating, dehumidifier is only 4 years old it does take out the water but very noisey any way to quiet it down?
May 02, 2010 | Whirlpool AD50USS Dehumidifier
My Goldstar Dehumidifier keeps cutting off even though its not full of water...any help?
A few things you could try are to make sure the float isn't covered in gunk and moving sticky-like, make sure air filters are clean and the compressor isn't overheating, and make sure the humidistat (probably a knob that says drier with arrows) isn't turning the machine off because it's reached the set level.
Nov 25, 2009 | Goldstar Dehumidifiers
Overheating
Jun 20, 2008 | Danby DDR606 Dehumidifier
Dehumidifiers Logo
209 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
