Question about Radio Communications
How do I install a oricom uhf058 cb radio in a 24 volt Mitsubishi truck?
Installing a UHF radio
Communicomm
  • 90 Answers
SOURCE: microphone wiring diagram
What is the model number?
Posted on Sep 05, 2008
Shuttle83
  • 1139 Answers
SOURCE: weather Radio won't work on 29 Nightwatch
Hello papapyr07,
It looks like you are trying to run the CB and the commercial radio off of the same antenna at the same time? This I gather is failing. This may be due to the pre-wired antenna having a filter on it to prevent exactly what you are trying to do. If this is the case you may have no choice but to run a separate antenna for your CB (this is the most logical choice), now you can try to find the filter if it is an external filter and remove it and use an antenna matching network to connect the CB to the existing antenna system (next logical, but may void the antenna system warranty). In any event you will either have to run another antenna for the CB or find and remove the present antenna filter.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 08, 2008
SOURCE: UNIDEN UH-011 UHF CB RADIO
i have just printed off a hard copy of this manual it was on Http//.www.uniden.com.au/ RESOUCES main/pdf/uh011.pdf If that isnt helpfull i could post it out to you.
Posted on Aug 09, 2009
  • 773 Answers
SOURCE: how do i install a cb radio on a pick up truck
You will need a CB radio antenna, The CB radio and mounting hardware as well as the power wire.
Choose a place to mount the radio. Mount it. Run the power wires from the radio to the fuse box. Put red wire in with the fuse that is hooked to switched 12 volt. Ground the black wire to any metal of the vehicle.
Next find a place to mount the antenna. If you use a mag mount, the roof of the cab is a best bet. Run the wire into the vehicle, it can go through the door, just make sure its not going to get pinched.
Hook the coax from the antenna to the radio
Now you have to tune the antenna. this is important because if you don't you you will blow the transmit final transistor out in the radio.
This link will take you to an article that will explain how to tune your antenna.
Posted on Nov 04, 2009
  • 141 Answers
SOURCE: installing a cb radio into car cd player. but I
Too much Feedback will result from running P.A. audio to the CD Player speakers.
Posted on Jan 30, 2010
Where can I get a Circuit Diagram for a Uniden UHF 012sx UHF CB Radio?
The only place you would get that is from Uniden themselves.
UHO12SX Manual - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH012.PDF
UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Features. 2. Preventative Maintenance. 2. Troubleshooting. 2. Controls/Connectors. 3. Missing: diagram ‎012sx
[PDF]UH8060NB - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH_8060NB_OM.pdf Operating the UHF CB Radio in Duplex Mode. 17. Scanning ... The Uniden UH8060NB is designed to provide you with years of trouble ... Built-in AVS Circuitry†.
[PDF]UHO12SX Manual.cdr - Uniden
https://www.uniden.com.au/RESOURCES.../uhO12SX_OM_2yrWarranty-Updated.pd... UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Controls/Connectors. 3. Indicators. 4. Included with your uh012sx. 5. Operation. UHF CB ...Missing: circuit ‎diagram ‎012sx
Circuit Diagram for Uniden UHF 012sx Google Search
Mar 19, 2017 | Uniden Radio Communications
6 pin microphone wiring diagram for oricom uhf058 pin has broken off
Yes does anyone know which wire goes where on the 6 pin oricom mic
Feb 18, 2016 | Audio Players & Recorders
Wireing diagram oricom uhf 088
Oricom UHF088 Questions & Answers - ProductReview.com ...
www.productreview.com.au > ... > Oricom > Oricom UHF088
Ask a question about Oricom UHF088 in UHF Radios. ... need a DC regulated power supply, you can pick one up from stores like from Supercheap Auto, Dick Smith or JayCar. ... I am after the wiring diagram for the uhf088 hand piece please?Missing: trucks
UHF088 UHF 5 Watt 2- Way CB Radio (in vehicle) - Oricom
www.oricom.com.au/uhf088-uhf-5watt-cb-radio-in-vehicle.html
Dec 29, 2015 | Cars & Trucks
How do I factory reset a oricome 200rx uhf
Factory reset
If the radio's display locks up or stops functioning properly, you might need to reset your UHF radio. Caution: this procedure clears all the information you have stored in your UHF radio.
Before you reset your UHF radio, try turning it off and on again. If your UHF radio is still not functioning correctly you may need to reset the UHF radio! While holding the F/DPX button, turn the UHF radio on. INITI AL will be displayed for 1 to 2 seconds, the radio will then return to its original display.
Oct 02, 2014 | Radio Communications
Wiring for 6 pin oricom mic plug
I too have an Oricom 6 pin mic with wires broken pin 1 is white, 2 is black and 5 is screen, this does not match any of the above answers and the green blue & red are off with 2, 3, 4, & 6 available
Kevin H
Jun 03, 2013 | Radio Communications
Got given a CB radio.. from a trucker... im in the [UK] wanting to put it in my car.. accept the voltage difference... a truck's voltage is about 24-volt's.. compared to a car.. only being 12...
I don't think there is a in accessories. The 24 volt truck systems are Cranking and Lighting. Either way you have no risk at trying the lower 12 volt car electrical. The problem is when you reverse polarity.
Aug 21, 2011 | Radio Communications
Installing echo board
red wire 12 volt all time conected to power supply and orenge wire 12volt when is on and 0 volt when is off ,this wired are in on off switch.
Mar 25, 2009 | Cobra 29 LTD CB Radio
Installing a CB Radio in a Mitsubishi Challenger
Take power off the fuse for the Radio. Use the cold side. EG: the side with no power when the fuse is removed. You can use the hot side if your DB has a fuse in line. Or you can slpice into the radio power line.
Jul 29, 2008 | Radio Communications
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
