Question about Kenmore Washing Machines
Washer does not finshing washer
I have a kenmore washer machine model 11092598200 I replaced the timer because it does not finish the cycle it stops before it gets to the rinse cycle the timer did not help can you tell me what else this might be?
  • 640 Answers
I aussume you have cold water,,,washers rinse in cold water.if you have cold water ,,replace the lid switch..part # 285671,,lid switch...onthejob
Posted on Jan 23, 2009
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Kenmore 800 series washer not draining; stops at that cycle; have to manually turn dial to spin/drain cycle to get it to finish; Need to trouble shoot n fix. Help?
After you advance the knob, you are saying that it will finish the rest of the cycle? If that is the case, more than likely, you will need a new timer for your washer. Hope this helps!
Aug 19, 2015 | Kenmore Washing Machines
My kenmore stacked washer/dryer has a wash cycle that can last for 12 hours. it will ultimately finish and clothes will be cleaned properly but it takes long breaks during the cycle.
The time it takes to do a cycle is determined by the washing machine timer. That is driven by a clock motor. This is an older machine so what is happening is that the motor on the timer is stopping and starting. A replacement timer is sold only as a complete assembly. I'm fairly sure you washing machine does the best job in the world in cleaning cloths.
Hope this helps,
Best,
Mark
Dec 30, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer does not stop at end of cycle.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.81863110&pathTaken=partSearch
This sounds like a Timer problem. (It's not stopping at the end of the cycle)
See also the Whirlpool / Kenmore Service Manual for these washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See also the following for how to gain access to the console:
You don't have to remove the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=cafe1d4847e92a9a9fbe0d1257575cf0
Apr 01, 2010 | Kenmore Washing Machines
Agitator does not work in Kenmore model
the agitator dogs are likely broken/stripped.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 10, 2009 | Kenmore Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Kenmore model # 20722990
It sounds more like the timer motor is stopping. There mght be something binding or a dead spot on the motor.The next time it does that, advance the timer slightly a few times and see if it then advances on it's own Check all the wires, too. Take the timer assembly out and flush it several times with alcohol or plastic safe electronics cleaner while operating the timer (engaged) several times.
Mar 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
79 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
