Question about Dell W5001C 50 in. Plasma HDTV
Regarding a dell W5001C 50" Plasma TV... when I connect a cable to the digital TV input and attempt to set up the TV, under "channel setup", antenna is selected and cannot be changed. Selection is "greyed out" so cable cannot be selected. Thus I can only tune channels 2-13 on the digital tuner. Any ideas?
    New Friend:
  • 90 Answers
Try a factory reset i think this will resolve the issue the passcode should be 3355.
Posted on Jan 29, 2009
Antenna unrecognized.
Sometimes the TV will lock out other inputs when a cable is connected. Try the antenna by itself and put the TV in Channel scan mode. If this works reconnect the cable TV cable. If that doesn't work you may need an A/B switch
Feb 19, 2018 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Digital tv tuner not displaying picture
. Try putting you tv set to channel 3 or 4. Try your tv in all modes. Check the back also to see if in the right spots with the wires. Check your channel scan status, try it on anntena and try it on cable, run channel scan on both. good luck. Try vcr wires if cable wires dont work. vcr wires are yellow red and white. Try another cable cord sometimes they get old. Try looking at your remote and setting it to tv.
Sep 02, 2012 | Panasonic PT-50LCX63 50" Rear Projection...
Why can't I use a digital antenna on my flat
Most televisions today have a setup mode for the tuner where it searches for channels based upon the input type. Older sets required the user to input whether or not the source was over-the-air broadcast, analog cable, or digital cable. If you were using your set with the cable or satellite system previously. you will most likely need to run the setup again with the digital antenna and let the set find the channels available via the antenna.
Jan 30, 2012 | Televison & Video
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Tv scream is blank it has sound,but no pictures
Switch off the TV Disconnect all the cables. Wait for some time. Connect all the cables. Switch ON the TV. It will work
Aug 02, 2011 | Dell W5001C 50 in. Plasma HDTV
How do I connect my digital tv converter box to this plasma tv. My antenna in and signal out are both co-axial cable. Which input do I use on the back of the tv? Would I use a BNC adapter to coaxial...
Here is a cheap and easy way to connect this for you....
Get a VCR (often times can be found at goodwill or garage sales for very cheap) and connect the coax cable from the output of the Converter box to the Antenna/Cable in on the VCR then connect from the RCA output from the VCR to the TV. Tune the VCR to Channel 3 most likely and change channels through the converter box.....
Good Luck and please rate this solution....
Jan 05, 2010 | JVC GD-V500PZU 50 in. Plasma Television
How to get the dell 4200 ed to pick up digital channels
there are 2 coaxial inputs on the back of your tv. plug the antenna into the digital coax. with your remote, do a fac reset: menu, setup, fac reset, all settings, passcode 3355. after the reset, hit input, select digital tv. perfprm a chan scan: menu, setup, channel scan, antenna. this should solve the problem.
Feb 09, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Looking to connect HDMI cable from dellW5001c to xbox360
192.168.15.1
i am appling this password. then username and password appling . plz help me
what is password and username.
Dec 27, 2008 | Dell W5001C 50 in. Plasma HDTV
Black on bottom of screen
do me a fovor, i need your firmware version? to do this, press Input 619. in the center of the bottom of the screen, is three digits 5?.? please provide me with these numbers. you may just need firmware updates.
Sep 28, 2008 | Dell W5001C 50 in. Plasma HDTV
Dell W5001C 50 in. Plasma HDTV Logo
139 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
