Question about Durabrand HT-3915 System
How to hook up Regent HT-391 Surround Sound System
Bought the system but there is no directions
2 Suggested Answers
SOURCE: REGENT MODEL HT391 SURROUND SYSTEM
you have to change the imput on the subwoofer
Posted on Oct 19, 2008
blkitalian
in order to watch tv and hear sound through this system u have to have r cabe going though either ur cable box or a vca anything that is cable ready u then hook the system in to that u will then have the sound going throu the system not the tv but if r tv has a buitl in dvd player u may be out of luck sorry lol i just figred this out after having it for more than a year
Posted on Dec 18, 2009
Tr-606 directions for use and remote
As long as your television and system both have (audio/out jacks from tv, audio/in to system) and cables it should hook up. Not real sure what you mean about directions for the remote, the system I have didn't come with directions just starts working as soon as the system is hooked up. Hope it helps
Feb 08, 2012 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Can you tell me what cords I need to buy to hook up the REGENT Home Theater Syster Model # HT391 suround system? Thanks in advance.
To what? Every device comes with a manual and (usually) the required cables.
Register and download the manual for free at audio.manualsonline.com
http://dl.owneriq.net/0/04645a11-2910-449f-abe0-93820c0bea7f.pdf
Page 7 describes the cables.
May 15, 2011 | Durabrand HT-3915 System
How can i directly connect a LG H30 TV, or a PS3 or a Wii to a Regent HT391 sound system? Is it possible to? So far the only 'surround sound' I can achieve is by connecting my tv thru the cable box...
According to the various vendors that carry this model, the unit has multiple inputs to accommodate gaming systems, dvd, tv, etc.
Look on the back of your system and see if there are inputs labeled as Game, DVD, TV, etc. You should be able to connect each component, and use the remote to switch between the multiple sources.
Good luck.
Feb 03, 2010 | Durabrand HT-3915 System
Need to know how to make the surround sound work through regular T.V. with durabrand surround HT-3915
Your regular TV set must be able to process the surround encoding through its output to where the Durabrand is taking the sound from.
Also, if you are using the TV set on a converter, Cable Box, or Sat receiver, and you are not taking the output from the component output there will be no surround from the source.
Surround sound is critical to how it is processed and applied.
Jerry G.
Feb 22, 2009 | Durabrand HT-3915 System
i need to know how to hook up my home theater to my TV and Dvd.
Oct 04, 2008 | Durabrand HT-3915 System
No sound when using dish or regular tv
This may be old news but just in case ...
Typically you need to consider the surround system as the central point for sound distribution (and in newer receivers, the distribution point for video signal as well). So you need to think of your TV and Satellite as sound sources and connect them to the IN side of your surround sound system. From the back of your TV then, look for the Audio OUT (commonly Red for right and White (or black) for Left. Connect these to the IN on the back of the surround system. Likewise for your satellite box. Then make sure you select the appropriate source on the surround system. If the system supports the video signal, you can route that as well. Beware that you'll need some sort of simulation (provided by the Phillips unit) to upconvert stereo to surround ... check the manual online. If you post model numbers for the Phillips and satellite units, we might be able to direct you more specifically (provided we can find manuals online)
Feb 24, 2008 | Audio Players & Recorders
Durabrand HT-3915 System Logo
2,151 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Rod
Rod
Geoff
Brian Sullivan
Brian Sullivan
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
