Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
All fuel lines have disolved and fallen off my Ryobi Edge trimmer
The lines had gone before I could memorise where they came from. Is there a diagram of the 3 fuel lines showing where they go to in the carbureter and where they come from on the petrol tank? I have new lines and primer button. I imagine that all Ryobi edge trimmers have a similar configuration in this area.
Thanks
Steve
  • steve_booker Jan 27, 2009
    Yes this is the setup to put in new lines. I cleaned the carbureter and fuel tank filter as well.
    Thanks
    Steve
worldvet
  • 859 Answers
SOURCE: Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Posted on Oct 28, 2008
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
#1 Taper
  • 1041 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • 64 Answers
SOURCE: Changing out fuel lines on Ryobi Trimmer, now when
the carb is plugged or the primer valve is sticky with gas varnish/gum
Posted on May 04, 2010
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Posted on Sep 04, 2010
My ryobi whipper snipper loses power when I turn it on its side.
If its gas powered, it relies on gravity flow to let fuel flow into the carburetor. When you turn it on its side, less fuel is flowing through the fuel line, meaning its not designed to be used as a side edge trimmer.
Nov 29, 2013 | Garden
I BOUGHT A LINE TRIMMER MODEL RTP-3000 AND IT WILL NOT OPERATE IN A UPSIDE DOWN POSITION WHERE MY OLDER MODEL COULD DO THIS
Many times often than not, your clunk connected to the fuel line in the tank has fallen off. Buy some new fuel line and replace the old one and it will be OK for a long time. Good Luck.....
Sep 23, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacing fuel line on trimmer model 775r - have have removed all the fuel lines and the bubble, but have forgotten the exact pattern to replacing the three fuel lines
Hi: I'm a new user to this forum. I recently had to repalse the 3 fuel lines on my ryobi model #775r. After researching the problem, I diagramed the flow of fuel in order to repace the fuel lines. If you require a copy of this diagram, send me an email . Regards, Tony
Oct 07, 2010 | Ryobi Garden
I need a diagram for the fuel lines on a ryobi 31cc trimmer plus 15" from the fuel tank thru the primmer bulb to the carb for both lines
Don't quite understand your dilemma... there are only two fuel lines which go from the tank to the carburetor.....if looking at the engine from the back, the fuel line on the left is the intake line and the one on the right is the fuel return line....on the back of the carb are two fuel line brass inserts...they are inlet on left and return on the right....hope this helps ;-D
Jul 15, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
210 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
