I have a vintage Sansui qrx5500, everything lights up, the meters show that the preamp is processing a signal but there is no sound, not even through headphones
  • John Warren Jan 15, 2013
    I've checked all the fuses, have the unit apart at this time and see nothing visually that appears to be the problem. Evidently, these used fused transistors that would fail over the years. The preamp section appears to function but the relay isn't pulling in to activate the amp board.
    Scratch that, I meant fused "resistors", not "transistors. I think it's time to take a break from the thing!
  • Audio Player... Master
  • 5,484 Answers
The problem is something to do with the power amp board. You need to determine if it is going power to it, from the power supply section. If it is it would indicate the main power amp has gone. Does it have an IC power amp? If it does then it's gone! Otherwise I am puzzzelled why both channels are down on a device with two seperate transistors stages.
Posted on Jan 16, 2013
  • John Warren Jan 17, 2013
    I've determined that the relay that must "click" on is not functioning as it should. I believe from what I have read about this particular quadraphonic receiver, is failure of the fused resistors. These units were built in the early seventies. What was used at the time as a early "protection" circuit for the amp, weakens over time. What I am trying to find is a decent detailed schematic, or picture of the board , with detail as to shich resistors need replaced with a metal film type of the same value. Audiokarma has several listings in their Sansui section, but no pics of the qrx5500.
2 Suggested Answers
SOURCE: Sansui QS-100 Problem with one rear channel
There are 2 250v 4a fuses inside the amp. They can blow and
that channel will cut out. Check the fuses.
Posted on Dec 03, 2009
No sound from system
Wrong process, first find out why no sound, soldered contacts very seldom fail. See if you have an input signal. see if everything is wired correctly. Check fuses if any. Check power.
Dec 11, 2014 | Audio Players & Recorders
Maudio 192 output
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
Sep 09, 2008 | M-Audio Audiophile 192 Sound Card
Sansui stereo remote
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
Apr 27, 2013 | Sansui Vintage Am/fm Stereo Tuner Tu-217...
Sansui A-909 LED indicator(peak power meter)
Check you have 14 volts on pin 3 of the driver chip for the meter.
Apr 05, 2017 | Audio Players & Recorders
Sansui AU-X410R Amp, at power on, lights on but no sound (surge protection click doesn't occur). Sometimes powers off for no apparent reason.
One thing you could look at is that thing that makes the click, it could be a relay and they do go wacky sometimes (hence why it shuts down). If you are lucky it will tell you (on the relay) everything you need to replace it.
Jun 11, 2010 | Audio Players & Recorders
Both fuses burnt and both clip and signal led on? seems to have full power behringer ep2500
Suspect an overload in either the power supply section or the devices on the main heat sink. In the power supply you are either looking at a transformer problem or semi-conductors associated with it. However since the clip and signal lights are on, I would go to the amp devices on the heat sink. If they are transistors test them with a Ohm Meter on the 1K setting in circuit even! You will soon notice which ones are gone! The meter will show like you had touch the test probes together!
May 15, 2010 | Behringer EUROPOWER EP2500 Amplifier
Sansui 2000x Phone 1 and 2 inputs produce garbled sounds.
I imagine everything is also VERY LOUD.
Only a Phono (old school turntable) should be plugged into the Phono inputs. It contains a preamp for the tiny signal provided by a Phono cartridge, plus is alters the frequency response drastically to compensate for the RIAA curve applied when they cut the record from tape.
Mar 26, 2010 | Audio Players & Recorders
Nov 19, 2009 | Audio Players & Recorders
Meters do not work on Sansui BA-2000
If you have an Acrobat 8 reader and PKware unzip / RAR , you should be able to open all that.
What if I send you one direct to your mail?
Feb 10, 2009 | Sony Audio Players & Recorders
Sanaui
This is a device which gives the illusion of more spacious sound by adding reverberation (echo) to the audio signal. This particular unit uses a mechanical analog delay mechanism employing a steel spring! Analog spring reverb units enjoyed some popularity in the late 60's and early 70's, with the Sansui and Pioneer units being the most common..
Feb 12, 2008 | Audio Players & Recorders
50 people viewed this question
 Grubhead
Grubhead
