Question about Alienware PC Systems Alienware m17x10-1847DSB Gaming Notebook
Laptop making a high humming noise that comes and goes
When I turn it on, the noise comes on and lasts for about 15 sec then goes off. Once it gets to my logon screen it comes on again, then goes off when screen is loaded. It will then come on if I start up any program and will go off 15 seconds or so after the program is running.
It sounds as if your hard drive is starting to go, either that or your cooling fan. These would be the only two things I can think of that would cause a "humming" sound. I'm also guessing hard drive due to the fact that the drive spins until the program is loaded into your RAM then lets the RAM take over so it gets quiet again. Just a thought, it doesn't cost anything to open the bottom and listen closely. Good luck!
Posted on Jan 13, 2013
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
I hear a sharp snap then a loud humming noise which sounds electrical. If I turn the refrigerator switch off, then on, the humming stops. Otherwise, it lasts 10 to 15 minutes. Its getting louder.
DID U CHECK UR EVAPORATOR FAN AND LISTEN IF THE NOISE IS COMING FROM IT? COULD BE BROKEN OR IMPEEDED IMPELLER HITTING SOMETHING ON START UP THEN GOING INTO A HUM?
May 20, 2015 | Sharp Refrigerators
There is a noise coming from my dashboard over the glove compartment of my lexus is 250
if it sound like clicking noise,most likely is the a/c servo motor. you need to inspect which one is it, because there is like 3 of them
Oct 09, 2014 | 2008 Lexus IS 250
Whining humming noise under hood
If the engine is not reaching optimum operating temperature it will indeed give you a "check engine light",the code will lean you in that direction as well.The noise your hearing more than likely is coming from the "clutch fan",they are very common on the TrailBlazers to make noise and fail.The oil light... you certainly need to have the oil pressure checked with a mechanical gage.
Apr 15, 2014 | 2006 Chevrolet Trailblazer Ext
I have a 50PL9220D DLP 50". Original problem was picture turned blue and had humming noise. Replaced lamp. Now have humming noise and picyure will come up fine for 5 sec then picture goes out. I have...
Sounds like the unit is going into a thermal protection mode. Probably something wrong with a transformer.
http://www.support.philips.com/support/service/service_page.jsp?userLanguage=en&userCountry=us
Jan 07, 2014 | Televison & Video
I own a Bose Acoustimass 7. I noticed humming coming from bass more noticeable than before (although I recently moved it to another smaller room) I also noticed when I hear this humming- the higher I turn...
I was having this very same problem. I finally figured out that I was getting feedback to the system because my TV cable coming into the house wasn't grounded right.
Oct 04, 2011 | Bose Acoustimass 15 System
I think that my fuel pump won't work because i can't start the engine anywaymy car is a dodge sprinter diesel 2007 (v6 , 3.0 l )
place key in ignition. turn to acc ,make sure radio is off listen for small hum it last about 15 to30 sec if you hear hum pump good . no hum check fuse if good more than likey bad pump. check if it has a glow plug
Mar 29, 2009 | 2007 Dodge Sprinter
Alienware PC Systems Alienware m17x10-1847DSB Gaming Notebook Logo
43 people viewed this question
Top Alienware PC Systems Computers & Internet Experts
Martin Murray
Larry Chandler
Jerry
Jerry
Are you an Alienware PC Systems Computer and Internet Expert? Answer questions, earn points and help others
