I turned head light switch on, bell will chime, is there a tail light module I should be looking for, and where is it:
Brake lights and turn signals are diffrent circuits. Take a long jumper wire and attach it to one of your parking lights that you can get to with easy access. Attach it to the positive wire. If you attach it to the negative it will spark. Once attached to the positive, trun on your park lights and see if all including dash lights come on. If this is helpful, please post as such. TY
Well, I just found my problem. I had a trailer hitch light that was somehow shorting the circuit. So everytime I placed a good fuse in the ext fuse slot, it blew it. I unplugged it, the trailer hitch light, and put in a good fuse, and presto! fixed.
no dash lights, no front and rear parking lights, brake lights work, turn signals work
I have the same issue. The dashlights work, just not the exterior lights.
I have the same problem and would love an answer. The fuses all seem just fine
which fuse do I look at if that is the problem, can't understand the fuse box
Do you have dash lights?
When car is off, dash and tail lights will turn on randomly. Occasionally the tail lights will flicker. Happens after car has been off for a while
