Question about Lincoln Electric LE 83180 Century Professional MIG/Flux Wire-Feed Welder
Century wire feed welder drive motor stopped working fan comes on electric is good
  • 5 Answers
SOURCE: owners manual for a century wire feed 83160 mig
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Posted on Apr 30, 2009
  • 5 Answers
SOURCE: The wire feed on my welder will not work.
Dale,
Probably the trigger/ open the lead and try to short the connections for the trigger by bypassing the trigger acuator. This is the mechanism that activates the wire feed motor and applies the welding voltage to the wire. If this works, get a new torch handle.
Posted on Jul 25, 2009
  • 5 Answers
SOURCE: wire doesn't feed
Either the trigger mechanism in the gun is bad, the servo that turns the feed wheel is bad, or you have too much tension on the adjustable tensioner knob. Take the wire out of the feed wheel, plug unit in and see if you can get the wheel to turn. If not, it is the trigger or the servo. If it turns, the tensioner was too tight.
Testimonial: "Haven't checked out your answer to my problem yet, but I will. I'am very happy about getting a response, others sites never answered back. thanks"
  • 225 Answers
SOURCE: I have a Blue Point Industrial mig welder,model
try readjusting your feed rollers(tension),plus make sure that your feed rollers are set for the right size wire your using.
Posted on Jul 29, 2009
SOURCE: Lincoln Pro-mig 175 w/ no wire feed but relay clicks fan runs
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The problem with my MIG 175 Pro is the "voltage selector switch" (part # M15750-1). I took it apart and saw all of the contact points where corroded. I can hold the knob between two settings and the machine will work.
I have the same issue only after about a year of very light use. I am not sure how to prevent this from happening again.
Posted on Sep 04, 2009
I have a lincoln sp-175plus, when trying to weld it the arc just melts the wire and it balls up at the end. I also put a new contact tip in. As well sometimes the wire feed just stops. I then press...
Your drive tension is too light. There are rollers that the wire feeds through and they need to be tightened. They should push the wire through the gun but slip if you put the tip against a solid object and pull the trigger. If they do not slip, they will jam your gun. Give the tensioner another turn.
Jan 08, 2011 | Lincoln Electric LE 83180 Century...
Difficulty changing the wire
check the tension on your drive rolls. Also check if the drive rolls are correct for that wire size.
Jun 27, 2010 | Century 80GS Flux - Cored Wire Feed Welder
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Wire doesn't feed
Jul 10, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Owners manual for a century wire feed 83160 mig welder
Paul
Apr 19, 2009 | Lincoln Electric LE 83180 Century...
Lincoln Electric LE 83180 Century Professional MIG/Flux Wire-Feed Welder Logo
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
