Question about Mitsubishi VS-4544 45" TV
Have sound but no picture
I have a Mitsubishi VS-4544 45" TV, love it when it's working. About once a month or two, the tv's picture goes out while you're watching it, but has sound. Last two times left tv off for a day and picture came on. I have a bad habit of leaving tv on 24/7, I know that something gets hot in there. Was told to soder video power supply. Not sure if this is the problem? I'm looking for service manual and/or schematics, or better yet "HOW TO" fix this problem. Can someone PLEASSSSSE help me?
    New Friend:
Dont no what to do
Posted on Jan 18, 2011
    Scholar:
  • 150 Answers
Solder alot of connections on power supply board and in deflection/ High voltage section on deflection board.
Posted on Jul 07, 2007
SOURCE:
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
Mitsu vs-5042 Works then picture goes out. Thumping works sometim
If you occasionally have a picture then you stand a good chance of repairing this tv. There are bad grounds on the deflection board. Start with the board that has the flyback. I do not know the year of your tv. Sometimes the same model may have an option improvement than one couple of months earlier. The first suspected problem would be the vertical IC. In some cases this ic is located on the convergence board and in others the flyback board. It has seven pins and is the TDA version. Located on a large heatsink. Resolder this and any other grounds on both board. Some will tell you the P I P board is bad. This is a free standing board that can be removed and replaced. But please do the earlier option first.
Jun 28, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
No picture
When I first turn the tv on the picture comes on for a few seconds then the screen goes to green but I still have perfect sound
Oct 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Oct 01, 2007 | Mitsubishi VS-4543 45" TV
Picture goes out after a few hours.
coul'be overheat solder the cause of a loose connection , and or convergence ic 's almost ready to fail . the cost to repair will be around 250.00 to fix replacing the ic's depending of the tech. or 350.00 at repair shop if you may have more question , let me know Im here to help you. thanks
Jun 12, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
237 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
