Question about Technical Pro HB-1502U Digital Hybrid Amplifier w/ AM/FM Tuner 1500 Watts
Technical pro hb1502u remote programming codes
Need universal remote code for technics receiver sar530
Go to the remote manufacturers website. Manufacturers assign their own codes to each program so the code for your receiver on a rca remote won't be the same as on a one 4 all remote. Sometimes they're even different in the same brand but different models of remote
Oct 16, 2016 | Technics Audio Players & Recorders
I have a kenwood rc-r0504 remote control. It is a multipurpose remote. How do I get it to control a Technics SL-PD887 CD changer?
Unfortunately, the RC-R0504 remote is not a universal remote. It can only control some Kenwood cassette decks and CD players, in addition to the receiver or other audio hardware that it came with. Since it wasn't programmed with codes for other device, there's no way to make it control a Technics CD changer.
I wish that I had better news for you. You'll need a different type of remote or to use both the Kenwood and Technics remotes.
Mar 23, 2016 | Technics Audio Players & Recorders
Needs technics receiver remote code for ct-90302
1768,1546,1083,1528. Check these codes. If you wish to get more codes to Technics, check this link.
Feb 27, 2013 | Televison & Video
I need the programming codes for TEAC Dolby HX Pro. I have a Sony Remote Commander which can access up to 8 components, but I don't have the instruction book containg the codes. I don't really need the...
First to clarify: are you programming the Sony Remote Commander to operate the TEAC? The AIR-RM10 (S-AIR Remote Commander) only operates Altus S-AIR transmitters and receivers. The code needs to be physically set in the battery compartment to have the units working on the same frequency. Then you pair or couple the devices (so there is no remote code involved). Other Sony device remotes only operate Sony brand products. Would you please clarify which remote you have? I'll be glad to check if your devices can be paired with more information.
Manuals (and codes where applicable) are available for most Sony products here: http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS&PRODTYPE=32 . You will need the model number of the Remote Commander to find your manual.
Note: the codes programmed into most remotes are limited to those for devices released at least 6 months before the remote was programmed. If your remote is older than the TEAC Dolby HX Pro, you may need a newer remote (or a different remote).
Please write back and I'll give you as much help as I can.
Mar 06, 2011 | Teac Televison & Video
I need a code for my Technics receiver SA-GX100 to program remote
technics codes:4007, 4008, 4026, 4045, 4073,
sony cd codes: 5001,5002,5099,5100,5101
sony vcr: 1001; 1002; 1003; 1004; 1005
good luck and vote for if it works
Aug 02, 2009 | Televison & Video
How do i get the codes to program my remote?
Here is the website for the manual for your model, The codes should be in there. (Technics and Panasonic are made by the same company)http://service.us.panasonic.com/operman/findmanual.aspx?model=SADX930
Mar 08, 2009 | Technics SA-DX930 Receiver
Cannot program my universal remote
buy the exact remote from parts store.com
Oct 25, 2007 | Pioneer PRO-200 60" Rear Projection...
Remote control code
You need to let us know the make and exact model number of the universal remote. All universal remotes do not use the same codes. We'll try to help you control your technics sa-gx100 upon your reply.
Sep 29, 2007 | Audio Players & Recorders
Technical Pro HB-1502U Digital Hybrid Amplifier w/ AM/FM Tuner 1500 Watts Logo
115 people viewed this question
Top Technical Pro Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Bapco
Are you a Technical Pro Audio Player and Recorder Expert? Answer questions, earn points and help others
