Question about Euro-Pro EuroPro Shark Navigator Vacuum
Why is my Shark vac hard to push on my Smartstrand carpet?
Can it be adjusted?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My shark vac is getting hot but hardlthe steam is coming out to
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
mn
Posted on Sep 25, 2010
Height adjustment doesn't adjust work. Vacum Too difficult to push.
Are you Missing the Front Wheels under the Vacuum? This asswmbly can fall off
May 25, 2016 | Hoover Tempo Widepath Upright Vacuum -...
How to adjust height on bagless dirt devil featherlite
Hello! The M085435 has an automatic height adjustment. The vacuum will adjust to the carpet height without you having to do anything. Hope this helps!
Apr 25, 2014 | Dirt Devil FAN, FEATHERLITE MODEL...
Heighth adjustment
Orecks do not have any height adjustments. If you have high pile carpet and an older model Oreck, you can purchase a high pile attachment and install that on your Oreck.
Mar 20, 2014 | Oreck Vacuums
Height adjustment not working
Manual says to tilt the vacuum back so the front wheels are off the ground (unit turned off of course) and make the adjustment. May take some back-and-forth force, but should adjust. If not, then something is jamming the switch.
Apr 19, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
How do you adjust a self adjusting vacuum. It's too hard to push because it's too low
honestly you cant adjust it. There is nothing you can do to it to make it adjustable either.
What I feel is the actual problem is maybe your belt is slipping on the brush roller and not making it easy to push anymore. a belt should be changed once per year, or if you are a pet lover, 2 times a year.
let me know how this works for you.
Good luck.
Mark
Nov 08, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
Jun 21, 2009 | Bissell 3920 Bagless Upright Vacuum
Slef propell is not working correct
The transmission may be out of adjustment.Remove the top cover exposing the pivot handle assembly.On top of the pivot handle assembly,you should clearly see the adjustment screw along with the adjustment spring.Once the adjustment screw is loosened,the spring should automatically adjust the pivot handle to the factory setting.Just make sure the screw is tight
Oct 23, 2008 | Kirby G6 Bagged Upright Vacuum
Problem with wheels
If the belt is over a year old, it should be replaced. This is normal maintenance and is often overlooked. When the handle is in the upright position, it will appear the the height adjustment is not working. What's actually happening is that the height adjust is easily moved so you can make any adjustment you want. When the handle is pulled back, the front of the machine will lower to that setting and lock, so it will not adjust itself while you are vacuuming. If you wish to change the setting, you have to return the handle to the upright position, or you can lift the front of the machine with your hand, taking the weight of the machine off the wheels and this will allow you to slide the adjustment to another position. It is possible that the adjustment mechanism has come apart. It is comprised of three separate components. It would be very difficult to explain it here and should be addressed by someone familiar with this model.
Jan 12, 2008 | Hoover U5264-930 TurboPower Bagged Upright...
Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
Aug 19, 2007 | Hoover U5753-900 WindTunnel Bagless...
Euro-Pro EuroPro Shark Navigator Vacuum Logo
1,037 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
