Where can I get a parts for a Dayton 55K salamander ????
I have a Dayton 55K kero sallamander heater that needs a new fuel filter and I don't know where I can get parts. Please help.
  • 140 Answers
Hello, go to this web site and they have the parts you need.
Any more questions please ask. Good luck.
Posted on Jan 23, 2009
I need a fuel filter assembly for a Dayton Oil Fired heater - part #099743-01. Do you have a supplier??
Dayton Heaters are sold by Grainger. If parts are available, you can order them from their parts department.
Jan 02, 2015 | Dayton Heating & Cooling
Where to buy need parts for 3E219B need new filters
Do you need air filters or fuel filters or both?
Jan 14, 2011 | Dayton E52 Utility Heater
Dayton 70,000 btu kerosene heater only runs consistently with 3/4 of a tank of fuel or more. Once it is below 3/4 it keeps shutting off. I have cleaned filters, tried to set pressure but pressure won't go...
If you can only get 4 psi from the pump then you have a problem with the rotor. This could be from the vanes not coming out properly of if you have replaced or serviced the rotor you may not have the clearance set properly between the pump ring and the top of the rotor.
Make sure to inspect the pump cover for any small cracks..
If you pump pressure in not enough the unit will not be able to pull fuel from the tank and you will see the burner cone slowly start to go from the orange color to a dark color and the unit will shut down.
Feb 10, 2010 | Dayton (3E386) Heater
I have a Dayton 110,000 BTU need back plate
Look up Grainger or WW Grainger on the web they should be able to help you find the part.
Jan 06, 2010 | Dayton Gas Furnace Heater
Will not ignite after replacing air filters
Clearly a problem with the new filter.
Does it have a check valve built in?
Try to get a flow through it without the nozzle attatched - and often there is a small sintered filter attatched behind the nozzle anyway. take off nozzle and try priming (without igniting obviously).
Could be air in there so needs priming. Often heaters shut down if air is present - so need to be bled of air. If you can pre-fill the filter, or bleed air at a joint just after the filter - this usually works.
Please rate at Fixya if this solves the problem. - It is free, and I improve my score if you do.
Thank you.
Feb 04, 2009 | Reddy Heater-30-55,000 BTU Variable
Dayton Salamander Heater - Blowing Unburnt Fuel/Smoke Randomly
I have seen this before, you need to replace the nozzle.
Feb 01, 2009 | Dayton (3E386) Heater
Dayton kero heater wont fire
your photo cell is bad or dirty its a little lens that looks threw the hole into the cumbustion chamber with two wires coming out of it.
Jan 15, 2009 | Dayton Electric Heater
Dayton kero heater wont fire0
OHH I bet this is the same question I just posted to. So it is a forced air kerosene. The usual is like I said a blocked combustion air hole. It could also be something shorting out the spark ignition to ground when replaces inspect the wires and look for a week or loose ground in this case. Sorry about the confusion.
A Bad ignition proving circuit or something like (what we call here dirt dobbers) hornets nest could be letting the flame hit it and not allowing full flow through the heater. Mice are also notorious for making problems like wires chewed and nests in the wrong place. Given where it may have been stored.
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
