Question about Gefu Kitchen Appliances - Others
Our gefu pasta maker is difficult to turn on the no1 setting
5 Suggested Answers
  • 14 Answers
SOURCE: Ronco Popeil Pasta Maker Problems
After using the Ronco Pasta maker for a few times I discovered a couple of problems, the main problems are that it's a bit slow, took as much time as it does for handmade pasta.
The second problems was that cleaning the dies was a pain!
Posted on Jul 16, 2009
  • 287 Answers
SOURCE: POPEIL AUTOMATIC PASTA MAKER
Just click on this site for everything you need. http://www.ronco.com/_downloads/RoncoManual-PastaSausage.pdf
Posted on Oct 01, 2010
  • 287 Answers
SOURCE: Instructions for a Pasta Queen Himark Noodle Maker
These instructions are for the same machine. Himark was bought by Atllas Marcato. http://www.fantes.com/marcato.html
lmmuresan
  • 131 Answers
SOURCE: looking for a manual for waring pasta maker model
Sometimes you can find them for purchase here: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=waring+pasta+manual&submit=Search&_sid=93311479
Hope this helps!
Posted on Oct 08, 2010
My Pasta Queen does not lock into the number settings
You are probably missing or have a bad cog in the setting gears.
Feb 24, 2013 | Marcato Atlas Pasta Queen hand-crank pasta...
TABLE CLAMP BROKE
These clamps can be bought 2 ways, look for pasta machine clamp or craft clay roller clamp on eBay. The clay roller entire machine set is much cheaper than the pasta machine, but they have the same clamp.
Dec 03, 2012 | Marcato Atlas Pasta Queen hand-crank pasta...
I cant seem to get the 150 to pull the pasta through the thickest setting. I am pretty sure that my pasta is thin enough to start.
The dough needs to be just right. It is sometimes difficult to get it started and the first couple of times through the machine the dough will be uneven and maybe break apart. Just put it through again and as the gluten develops from the handling, it will smooth out and be more workable.
Good luck. If you would like to see a video, try this link.
Feb 15, 2011 | Imperia CUCI 150 Fresh Home Pasta Machine
Pasta Machine turning pasta sheets out with lots of holes? What are we doing wrong?
Start with the rollers farthest apart and when you first start rolling the dough will be uneven and have a few hole. But as you roll the dough over and over, it will be smooth with no holes in nice flat sheets. Rollthe dough twice on each setting, starting with the biggest number and rolling down to the smallest number for very thin sheets of pasta. Good luck. I have a recipe and videos on my website at http://noodlemakermachine,com.
Jan 16, 2011 | KitchenAid Kitchen Aid Pasta Maker...
What is the safe way to clean it?
Wash in the sink with a toothbrush and normal dish detergent. Don't place in the dishwasher because the food particles will get into the machine. Difficult spots, clean with white vinegar only.
Aug 30, 2010 | VillaWare Al Dente Pasta Machine Chrome...
The handle on our Marcato Atlas 150 keeps getting stuck and is difficult to pull out for storage. Any ideas?
I opened the rollers to the widest setting (Zero), and placed a folded business card between the rollers. I then turned the dial down so the rollers were "pinching" the card, and while keeping tension on the dial to gently squeeze the card, I gently shook the handle for a few seconds and it came out!
Jan 12, 2010 | Atlas Translator Marcato Atlas 150 Handle...
My Popeil Pasta maker quit in the middle of the mixing cycle. It is just dead, is there a re set switch?
The switch has 3 positions. Motor does not work ff that switch is in the middle position. Check the position of that switch.
Sep 05, 2009 | Ronco Automatic Popeil Pasta Maker
I need a manuel for a pinzon pasta maker any ideas
I'm not sure if I can find you a manual,but I do own one similar to it, so I can tell you how to use it.
First make sure it's clamped down securely.
Run your dough through the first setting (1). If you want the past thinner than this,just keep pulling out the knob and adjusting it to the number that coincides with the thickness you want. So...start at the first setting...insert dough...turn the handle to run the dough through. For thinner pasta adjust to the second setting,etc. When it reaches the desired thickness run it through the section that has the grooves. On mine I have to pull the handle out and move it over to the other slot...looks like it's the same deal for your's.
Hope this helps.
Sep 01, 2009 | Pinzon Pasta Maker
How to clean the Ronco Popeil Pasta Maker?
The Ronco Pasta maker is a bit of a pain to clean. I normally take the whole thing apart and put it in the dishwasher and that does a good job with most of it. Occasionally I will need to run it in the dishwasher twice. The middle piece has to be cleaned by hand. You can finish it off in the dishwasher after you clean out the junk in the middle part.
The dies are the real problem when it comes to cleaning this unit. You need to get a small wire to flush out the holes otherwise the dough dries inside the dies and they are very difficult to clean out. Just running it through the dishwasher will not work. I either use the wire or I boil the die for 20-30 minutes then put it in the dishwasher.
Jul 16, 2009 | Ronco Automatic Popeil Pasta Maker
Kitchen Appliances - Others Logo
23 people viewed this question
Top Gefu Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Gefu Kitchen Appliances - Other Expert? Answer questions, earn points and help others
