Question about Dell Inspiron 5160 Notebook
Wirless wont connect
I think my internal wireless card is loose or fried and I want to change it and am not sure how to remove it , is there an esy way to remove it to replace it thank for your input?
    Master:
  • 474 Answers
Try going here for any manuals or driver downloads you may need. try re-installing the drivers before condeming the wireless card.
http://support.dell.com/support/edocs/systems/ins5160/en/SM/upgrades.htm#wp1107296
If you decide you want to replace it, you will need to first remove the MINI PCI adapter cover from beneith the laptop.
Inside you will probably see a small chip with a wire connected. That is the regular telephone modem for dial up.
The second, bigger one is the wireless card. It should have two metal spring locks on the sides , depress these and it should pop up slightly. then just pull and it should come right out.
getting another just like it may be hard, try ordering one from dell or going to a computer store with knowledgable people and see if they can get you one.
Let me know if you need anything else or have any questions.
Posted on Jan 23, 2009
  • Chris Busch
    Chris Busch Jan 23, 2009
    First, you can go to http://www.support.dell.com/ and you can download the manual and any drivers that you might want to use to try and get that card working.
    To remove it, you usually have to remove the wireless card by removing an access panel on the bottom of the laptop and unhook any anntena connectors.
    Now this model has a mini PCI connection under one of the panels where it has a regular modem and then a slot to put a wireless card. it should be the bigger of the two and is held in by two metal spring locks on the sides. depress those, it will pop up and you pull it out.
    Have you tried re-installing the drivers or done any troubleshooting at all?
    Has the wireless ever worked?
    What, if any, are the symptoms?
    Please let me know.
    Depending on the model or if its older, it may not have anntena connectors.
Wireless adaptor broken!?
Alot of times you can go into the properties of your wireless card and clear from the list all the access points you have connected to recently and in the past and it will help.Also check to be sure the wireless card is turned on.I've found that internal wireless cards tend to fail after a while due to heat and use.I would replace the card if clearing it of it's memory doesn't work.Also check to make sure that both antenna's are connected properly to the card in case they came loose.I tend to think the card is bad though.
Aug 28, 2012 | Toshiba Computers & Internet
Why wont my xbox go live from my wirless router
Make sure it is connected to the network ...To do that be sure it has a functional wireless card ..engage it ..and search for networks ...Identify your network ..and click connect ..Insert your network password when asked and wait to connect ..You have to do this each time you power it up if it does not hold the connection by itself ...To hold and remember the connection ..set the card for it ..
There can be no other fault but a damaged wireless card or a faulty setting on it ..If you still have the drivers for it try to reinstall them if you think it may be damaged..
If it works with the cable ..it should work wireless to ..
Dec 04, 2011 | D-Link Computers & Internet
I m unable to use my wirless internet.my belkin802.11gadapter is not connecting for internet
First thing to do is to re-configure the wireless router that you have. Change the name and wireless password. After that, re-install the Wireless adapter on your desktop. Make sure that you will clean all the files installed on your system. Then test if other wireless device can connect to it.
Jun 04, 2011 | Belkin 802.11g Wireless Desktop Network...
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
Dell pc will not work with linksys router
HI Boston
I believe the wireless card that you have in your laptop is a dell wireless card.
Here are the instructions on how to get your wireless working
Start-All programs-dell wireless-dell wireless wlan card utility-open the window and on the uncheck let this tool manage your wireless.
Please make sure that Enable radio is checked otherwise no wireless networks will be detected by the computer.
Once that is done go to start control panel in the left hand side make sure classic view is what is there. Go to network connection and you would see wireless network connection. Right click and click on view available wireless networks.
click on refresh network list if any of the networks are not seen.
Still no go try to enable the radio of your wireless card by pressing fn+F2 and then try.
if your getting limited or connectivity right click on wireless network connection go to properties, select on the top the tab wireless networks and remove your network from the preferred networks click on ok.
now get back to view available networks and try to connect to your wireless network.
make sure if there is a security on ur network you are aware of the ntework key and its case senstiive as well. otherwise ask linksys to give it to u.
if your wireless says connected check the ip address and post it here . for finding ip address start-run-cmd-click on ok
in the command window type ipconfig and post the ip address here.
alternatively also try updating the wirless card from the site
thank you do post your results and feedbacks if any
rakesh
Dell Laptop Expert
Jan 09, 2009 | Dell Inspiron 6000 Notebook
I have a acer travelmate 3000 laptop and cant get my wireless to work, if i plug in a new wirless usb stick it works fine but i wont the internal wireless to work, does this mean my internal wireless card...
Odds are pretty good the wireless is not enabled.
If you look at page three item three of the manual, it shows the button/indicator on the front of the system to enable wireless.
http://www.acerpanam.com/synapse/data/7117/documents/TM3000_UG_Eng.pdf
Jul 17, 2008 | Computers & Internet
ThinkPad R32 Overheating
Its more likely the fan has stopped working. I recommend taking it to a qualified repair shop.
May 21, 2008 | IBM ThinkPad R32 2658 Notebook
Wireless internet is not working my wirless card does not work
remove network connection for wirless,
remove wireless card,
reboot,
then shut it back down,
while off reinstall wireless card then boot back up,
it should ask you to configure it.
May 02, 2008 | Computers & Internet
Dell Inspiron 5160 Notebook Logo
Alun Cox
