Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox model# 19e604-00aa stuck in demo mode
We have this magnavox tv from 1994 model# 19e604-00aa, we have lost remote and have been turning the channels by hand, somehow my kids have put it to demo mode and we can't get it to undo itself. is there a way to fix it with out a remote or is it trashed....
  • Anonymous May 13, 2009
    omg ihad the same problem ur a huge help we had rwo tvs like this and i just fixed them both thx a bunch
Press +vol and -vol buttons on the tv at same time.
Posted on May 04, 2009
1994 magnavox tv stuck in demo mode. Model#TS3270B101
With the set ON. Press the volume up AND volume down at the same time. OR
Press the channel up AND channel down at the same time.
Oct 01, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tip
How to Disable Philips Magnavox Demo mode
  • Many people are annoyed about demo mode coming out of nowhere and causing problems with many Magnavox televisions there is a simple process which will allow you to disable the demo mode.
  1. Television must be turned off But remain plugged in
  2. First You must place both your fingers on the VOL + and VOL - buttons on the television.
  3. Then Turn on the television while still holding the volume buttons in for about 6 seconds..
  • The demo mode will now be disabled, Some televisions may turn off after demo mode is disabled just use remote to turn television back on or use programme up and down button on television to turn it on.
  • This will work even if you don't have the original remote as it requires no remote at all its a simple process and it will work with nearly all models of Magnavox televisions.
on Aug 01, 2010 | Philips Magnavox 27MS343S 27" TV
I have an m# ts3270 b101 stuck in the demo mode. would luv answer to problem, i am draining my family of their patience.
Man o man, just moved my same model Magnavox and have the same problem. Staying in demo mode...
Dec 18, 2010 | Philips Magnavox 27MS343S 27" TV
TV is 1995 Model 25TRC1-0101 Magnavox. Seems to
The tv has been accidentally set for "demo mode". Press the volume up and volume down buttons in front of the TV at the same time for about 5 to 10 seconds untill the demo disappears or sometimes the TV will turn off. You should regain control of the TV after this.
Jul 19, 2010 | Philips Televison & Video
I have a 1996 magnavox tv that is in demo mode and you can only turn the tv off by unplugging the tv
Those older Magnavox sets had a demo mode available from the on screen menu. Go to the menu and disable the demo mode, that will fix the trouble. When in the demo mode you will have no control over your set by remote or front panel controls. You can still address the menu though to turn off the demo mode.
Apr 17, 2010 | Televison & Video
Magnavox MODEL # HD1905 C121 CHASSIS # 19E604-00AA SERIAL # 43468127 My Magnavox is stuck in a demo mode. I cannot turn the power on or off, and NONE of the buttons work, nor does the...
on the set press and hold the up and down volume buttons together till the tv turns off then press power to turn back on and everything should be fine
Jun 10, 2009 | Philips Magnavox 20MS3442 20" TV
Magnavox tv is stuck in demo mode or something. It is from the 90's. I don't know the serial number off hand, but I need to get it out of demo mode. I tried the volume up volume down buttons. I can...
If you can find the model number (probably located on the back of the TV) you can go to the magnavox website at www.support.magnavox.com and search for your model number. They have troubleshooting tips and tricks for a lot of common problems. You may need to speak with a representative directly to help solve your specific problem. After you find your model on the website, you can download the user manual from the left panel, which may help as well.
Dec 05, 2008 | Televison & Video
TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Nov 30, 2008 | Philips Televison & Video
Magnavox television stuck in demo mode
My wife somehow put our Magnavox TV into demo mode too...
Plug in the set. With the set ON. Press the volume up (+) AND volume down (-) at the same time.
This worked to get it out of demo mode!
Jan 03, 2008 | Televison & Video
My 19" Magnavox won't come on.
LOL its in a demo mode man!! simply hit the menu button on the original remote and go to the special settings and turn them off. If it still does not work, then the painter or the Microprocessor Ic Needs to be replaced.
Sep 09, 2006 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
340 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
